588,232 active members*
4,962 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > ACE V400 spindle position to high for tool change
    Feb 2016
    5
    Hi all,
    I'm currently working on a ace v400 twin pallet machine which has recently been moved from building to another and the problem i have is the spindle is to high for the automatic tool change i was wondering how i could go about lowering it to the correct position.
    Thanks in advance
    Jun 2004
    511
    Re: ACE V400 spindle position to high for tool change
    It sounds like your axis reference, or 2nd reference is off. The manual should tell you how to reset that.
    Feb 2016
    5
    thanks for the reply i have got the position right now but it will only work when i turn it on holding p + can if i dont do that it alarms out with a z axis overtravel alarm
    Jun 2004
    511
    Sounds like your stored stroke limits are off.
  1. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  2. Hardinge Spindle lost tool change position
    By Ph2011 in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2014, 04:43 PM
  3. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  4. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  5. Arrow 500 spindle tool change position
    By mmckell in forum Cincinnati CNC
    Last Post: 02-15-2011, 09:56 PM
