588,506 active members*
4,962 visitors online*
Thread: BT30 Spindle
Page 10 of 29 8910111220
Results 181 to 200 of 570
  1. #181
    Mar 2014
    1133
    Re: BT30 Spindle
    Thanks hanermo.
    I just started to drill. I think this will take some time.
  2. #182
    Mar 2014
    1133
    Re: BT30 Spindle
    I'm not planning to cut a labyrinth seal for the back (upper) side. However I'll cut a cover which has .01-.02mm gap to the shaft. Also the 80mm dia pulley will be very close to the cover, maybe the same gap which is .02mm. So the pulley and the cover will act as a labyrinth together. What do you think?
  3. #183
    Aug 2014
    889
    Re: BT30 Spindle
    Quote Originally Posted by Azalin View Post
    If the pulley is that close it will act as a slinger when running. When stopped then don't immerse it in coolant.
    Did you finish boring?
  4. #184
    Mar 2014
    1133
    Re: BT30 Spindle
    Yes and it's better than a labyrinth I guess.
    Quote Originally Posted by G59 View Post
    I have strong migraine attacks these days as the weather is very unstable so not much progress.
  5. #185
    Aug 2014
    889
    Re: BT30 Spindle
    Not fun. Hope you feel better soon.
    I enjoy following this build. It reminds me of the way I used to build them.
    Slowly but surely you'll get there.
  6. #186
    Mar 2014
    1133
    Re: BT30 Spindle
    Thank you.
  7. #187
    Mar 2014
    1133
    Re: BT30 Spindle
    The exterior of the body is almost ready. I left .1mm material for grinding. Now I can bore the inside.
    Is it recommended grinding the bearing houses on the body or just cutting to the right dia is OK? If grinding is needed I'll have to make a hole grinder.
    Sent from my GT-I9300 using Tapatalk
  8. #188
    Aug 2014
    889
    Re: BT30 Spindle
    Why grinding of the exterior? That's estetics only. The bearing surfaces benefit the most from grinding. But, it doesn't have to be. Just keep your tolerances in check and check for "roundness" of the bearing surfaces.
    Nice job.
  9. #189
    Mar 2014
    1133
    Re: BT30 Spindle
    Cool. Because grinding on lathe is a real mess.
  10. #190
    Mar 2004
    1306
    Re: BT30 Spindle
    You got a nice finish on that.
    Mark
    Regards,
    Mark
  11. #191
    Mar 2014
    1133
    Re: BT30 Spindle
    Thanks Mark. Yesterday I started to bore the inside. It wont take long to complete the interior.
    Next thing is to drill the holes on the outer labyrinth seal. I'll do this on my CNC.
  12. #192
    Mar 2014
    1133
    Re: BT30 Spindle
    Still working on it. Small lathe small passes.
  13. #193
    Mar 2014
    1133
    Re: BT30 Spindle
    I was about to cut the inside for the bearings but to get the best squareness I checked the housing with my dial indicator. It seems like the chuck isn't that precise. I used a piece of 0.05mm SS sheet between the jaw and the workpiece. It solved the problem perfectly.
    https://youtu.be/Q6TXCyBnkmQ
  14. #194
    Jan 2008
    1543
    Re: BT30 Spindle
    Are you unchucking and rechucking the workpiece in a 3 jaw? That will never be accurate. You need a 4 jaw (independent jaws, not self centering).
  15. #195
    Mar 2014
    1133
    Re: BT30 Spindle
    It's a 4 jaw chuck but self centering.
    Everything went well until now. Next is to drill the holes in the labyrinth outer part. I'll do this with my CNC.
    It comes together:
  16. #196
    Aug 2014
    889
    Re: BT30 Spindle
    Looking good. You ground the OD I can see. If not then, nice finish. Carbide or HSS for finish?
  17. #197
    Mar 2014
    1133
    Re: BT30 Spindle
    Thanks. The OD isn't ground. Just turned with carbide indexable. There is a .1mm material left on the OD for grinding. I'll do that when everything else is done.
    The gears on my lathe is set to 0.01mm per revolution. That give me a nice finish.
  18. #198
    Mar 2014
    1133
    Re: BT30 Spindle
    By the way, I got some 6xxx series bearings. I'll do all my tests fittings etc with them. That way my angular contact bearings remain new and clean. : )
  19. #199
    Jan 2014
    BT30 Spindle
    Nice work on the spindle! I used to have a Bridgeport R2E4 CNC and it had a NTMB30 spindle. I still have end mill holders and collet holders as well as bench block for tool changing and TOL micrometer stand with micrometer. If interested I will sell for a reasonable offer. I can supply photos if you request.
  20. #200
    Mar 2014
    1133
    Re: BT30 Spindle
    Thanks Mark. What is your location?
  1. Bt30 or bt40 spindle
    By KKamel in forum Spindles / VFD
    Last Post: 12-14-2015, 10:03 PM
  2. BT30 Spindle Help
    By Momentz in forum Benchtop Machines
    Last Post: 11-03-2015, 01:08 AM
  3. Looking for a BT30 Spindle
    By xtwalt in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2012, 10:10 PM
  4. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  5. Reasonably priced BT30 ATC spindle.
    By dwalsh62 in forum News Announcements
    Last Post: 05-12-2011, 05:59 PM
