Originally Posted by
mike_Kilroy
i sent you an email:
You said:
yes I put bad commands ,is my first time that I used motionlink plus.
I'll tell you as I have understood what to do, if I'm wrong you can tell me what I have to do and how to do it exactly, please
open motionlink plus , go to terminal, type RDRES=12 enter , type ABAUD=0 enter . this is I need do ????
Yes, BUT
FIRST type in P RDres & P ABAUD to SEE what they are set to now!
THEN correct them if needed.
Since it is batt backed Ram, no need to 'save' them - just typing them in saves them.
Attached is .TL file.... remember that motionlink is 20 yr old program so file names can only be 8.3 in size....
how to load it?
let me try to count steps:
start motionlink plus
when asked to BREAK program, pick YES
click on CONFIG icon top
click on OPEN on right
pick the sample.tl file from where you copied it onto your hard drive
click on XMT on right to SEND it to the VFS5 drive
hour glass rotates showing it is busy going....
When done, exit motionlink plus
cycle power to VFS5 to restart it (not required to load new TL, it will be active immediately, but to RESTART the internal program -easiest way to explain how to do that)
Hope that fixesw your problem - let us know...
