Hi folks,
Trying to expand the memory of a Fanuc 16 TTA with a 1 Meg module. Backed up and replaced the module OK.
When I restored, the tape memory is smaller than before
Being a Fanuc 16A there is no PCMCIA card slot, just a RS 232 port for file transfer.
The transfer works fine but I can't see a way to loading a blank 512k SRAM file to clear the new RAM - file is for a Fanuc 16B perhaps, found on the net.
I can load some small part programs but transfer stalls on the file which is much larger than the present undersized memory.
Initialised with reset & delete on power up with parameter write enabled before restoring.
Set the 99xx parameters for a main and sub memory as per TTA requirements.
Also have checked out other posts, any ideas thanks?
