587,999 active members*
1,979 visitors online*
Results 1 to 6 of 6
    May 2016
    RFQ: Small Parts From Brass Tube
    Hi Everyone,
    I need this small part machined from 5/64" Brass tubing:
    Basically (I think) it would involve clamping a length of tubing in a jig, machining the contour (designed with milling in mind), and cutting off the end to form the final part. Here are the files:
    https://drive.google.com/folderview?...lE&usp=sharing
    I need 10 pieces to start, with an option to scale up to more that 100 pieces at a time later on if the project is successful. I can supply the tubing or you can, currently the tubing is being sourced from special shapes company.
    Thanks,
    David
    Re: RFQ: Small Parts From Brass Tube
    I think I'll be able to help you out with this. I'll send over a quote in a bit- Can you PM me a good email address to reach you at? Thanks,
    Nick Polanosky
    P3D Creations
    Feb 2014
    92
    Hi David,
    We are interested to provide the quotation. Can you let us know your email address so that we can communicate? We can be contacted through this email [email protected]
    BR
    /SL Wong
    Sales Manager
    Proto Tree LLC
    Website: Proto Tree
    Email: [email protected]
    Mar 2008
    22
    David,
    I am interested, Email Me [email protected] So I can get some more detail
    Thank You
    Matt
    Micro Shaped – Shaping The Future
    Mar 2016
    6
    Private message sent. Looking forward to hearing more about your project.
    Apr 2012
    51
    Do you have a source for the tube? What are the tolerances?
  1. RFQ: 25 or 50 small brass lathe parts.
    By RickK in forum North America RFQ's
    Last Post: 07-10-2015, 05:31 PM
  2. Small problem turning brass
    By thoru in forum MetalWork Discussion
    Last Post: 01-15-2015, 09:16 PM
  3. RFI - CNC tapping small holes in brass & aluminum
    By mhackney in forum Benchtop Machines
    Last Post: 01-14-2011, 08:57 PM
  4. RFQ: Small Brass Pins
    By sleepy23 in forum Employment Opportunity
    Last Post: 02-23-2010, 03:30 AM
  5. Parting brass tube
    By fatal-exception in forum MetalWork Discussion
    Last Post: 12-09-2009, 11:25 PM
