Thanks Everyone for your imput, I did try and remove the Case but 1 screw is stripped and I don't really want to bend/force it open. I'm Happy with what I bought, this is what I was after, a CNC Router that can accept a USB or SD Card without a Computer involved, couldn't really find anything that allowed you to use a full size USB Drive so the Micro SD was the next best thing. Once I understand it and get all working then I will be as happy as Punch :-) I run my Laser Cutter from a USB Drive so now I can keep my computer in my office and do all my work there and just update either machine when needed.
***UPDATE***
The Company has gotten back to me with something thats useful, the Past week they have been refering me to everything that aimed at a Controlbox controlled by a cable ( Would have thought photos I sent and Where do I plug the Serial Cable in might have been a Big Hint to them? ) So finally I have the machine running ( Well Running the first line or two before I RESET it ) just taking things bit by bit. So I can load any GCode file and everything begins to run when I Click RUN. Next I went to setup the Probe ( Thats why I haven't tried to run a complete Program yet ) what I did find was none of the Limit Switches are activated so when I go to the max or Min Distance with XY or Z the Spindle tries to continue past the limit switch and you hear the GRUNT of the Stepper motor when it can't go further. I have emailed them asking them for the Settings to control this so just waiting for their reply.
Here are the two images they sent me to correct the Reset Error on movement. Also a Video that at least explains a couple more icons on the controlbox https://youtu.be/w2WbhDCdToU
