588,619 active members*
4,383 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Apr 2013
    1788
    PP 1.9.6 available
    Version 1.9.6 of PathPilot is now available for download from http://www.tormach.com/pathpilot_tracking.html
    Goodies include conversation bolt circles, search in the GCode editor, serial number engraving, etc. Curiously, no mention of RapidTurn support!
    Who volunteers to be the first to try?
    Re: PP 1.9.6 available
    Not me, but looking forward to see if Rigid Tapping works in Lathe Mode.
    Donald
    Apr 2011
    720
    I was a little surprised, when I heard about the pending release I expected it to have something to do with the RapidTurn because of the timing. The email does say there is a rigid tapping bug fix.
    Jan 2016
    3
    I have been running it all day today, from 10 am this morning, its 10pm here right now and its still running fine. (so no, the sky has not fallen...not yet anyway)
    I have not had a chance to snoop around to look at all the changes, however all the stepper axis motors on my series 3 PCNC 1100 sound quite different.
    I also noticed it wanted to update my mesa card during the update.....
    Jun 2014
    1774
    I have been waiting too ha! I would like to see if the hesitation during a contour cut is fixed, I have to add a Q.001 in the startup line.
    I think the serialization feature will be nice.
    I like new things but I dont like crawling under the machine to get to the computer, I will wait a bit ha!!
    mike sr
    Apr 2013
    1788
    Things are a little slow here so I took the plunge and upgraded from 1.9.3 to 1.9.6. The upgrade from USB stick only took a few seconds but it decided to update the Mesa card so a power down was required. I backed up the tool table ahead of time but it made it thru the upgrade without problems. I've been working on some new parts I haven't noticed a different sound to the steppers as Godzilla mentioned. No problems with with probing a circular recess as was reported with a previous upgrade. No obvious RapidTurn goodies. However, there is still the annoying screen flicker when waiting for a tool change!
    Dec 2008
    740
    Quote Originally Posted by kstrauss View Post
    Attachment 325244
    Step
    Apr 2013
    1788
    Thanks for making me look more closely at each screen! On a slow computer it takes less than 10 seconds to go from mill to lathe. As previously speculated, going from mill to lathe and back requires that one re-reference. I notice that there is a "Gang Tooling" choice although I haven't seen any Tormach mention of that option for the RapidTurn. Any insights regarding how that works?
    Nov 2007
    2151
    I was hoping for search and go to line number in the g-code window! After all this time and a person still has to scroll down thru hundreds to thousands of lines to find a start location. Such a simple and useful feature imho that has been over looked for years now
    Jul 2004
    1424
    Quote Originally Posted by mountaindew View Post
    One of the 1.9.6. features:
    #965: Mill/Lathe - G-code window: Add ‘Goto line number’ and ‘Search’ utilities to right click menu
    Did you suggest that enhancement?
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Jun 2014
    1774
    The search function from the MDI line will find many things in the program such as tools line numbers etc, I havent played with it much but from what it appears to be it will do what you are looking for.
    I needed it the other day to restart a program at a certain tool number, as you say it is sometimes a daunting task! I wound up rerunning the program without a tool until it called for the one I needed, wound up being much faster ha!
    Usually I just go back to sprut and eliminate the ops before the one I need and run it as a separate program, but I dont think I will need to do that now with this new search function.
    mike sr
    Dec 2008
    740
    Quote:
    Code:
    # type of tool changer is set by the UI via tormachltc.0.tool-changer-type, RapidTurn supports manual only
    # 0 - manual
    # 1 - gang
    # 3 - 8 position ATC
    which doesn't mean it can't be done
    Step
    Nov 2007
    2151
    Quote Originally Posted by tmarks11 View Post
    I did just a few days after the second release a couple years ago. Did not need it as much in version 1.9.2 because the code window retains position. The next release this changed and when a program is stopped it returns to beginning of program. Anyway, I suggested a search or other method to find an operation or place in the middle of a program and others have also.
    I will look again but #965 does not add this functionality to my PP install as much as I was hoping it would!!!!!!
    Jul 2004
    1424
    Quote Originally Posted by TurboStep View Post
    Quote:
    Code:
    # 0 - manual
    # 1 - gang
    I see a new product enhancement possibility... an 8 position tool changer mounted on the side of the spindle for rapid turn.....
    Tim
    Jul 2004
    1424
    If you haven't looked at the Tormach manual in awhile, I would recommend paging through it.
    Since the initial ParhPilot release, they had greatly expanded the sections on dealing with PP. The latest version (6-2016) includes discussion of how to use the new features of 1.9.6.
    Tim
    Apr 2013
    1788
    Thanks! I hadn't noticed the new version of the manual.
    I tried to use the ADMIN DATE command. It lets me change the time zone but when I try to install NTP I get a 404 error when fetching the package. The help screens work for date/time admin which I think are fetched from the net. Ideas?
    Oct 2010
    136
    I've been using 1.9.6 for several projects now and the only issue I have seen is in MDI mode. After sending a line by hitting the return, PP pops out of MDI mode. I am fairly certain this was not happening in 1.9.5.
    This only led me to write a program instead, which usually a better idea anyway.
    Oct 2010
    253
    If you are line number oriented, why not include line numbers in your gcode and search on that line number. Eg, 'FIND N123'. Seems it would do the same thing.
    Nov 2007
    2151
    Quote Originally Posted by adamvs View Post
    How do I search a g-code program when it is loaded and ready to run?
    Where do you enter a 'find n123' at.?
    Oct 2010
    253
    In MDI. It's in the docs with the download. I tried this yesterday with 'FIND G30' to set start line. Pretty cool, really.
Page 1 of 2 12
