587,680 active members*
3,732 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > NEMA 23 and Driver Setting Question
Results 1 to 6 of 6
    Jul 2016
    3
    So I have just purchased a NEMA 23 [High Torque Nema 23 CNC Stepper Motor 3.5A 3Nm(425oz.in) 23HS45-3504S], a Motor Driver [2/4 phase Nema 23 Stepper Motor Driver 24-50VDC 1.5A-4.5A 256 Microstep M542T] and a Switching Power Supply [Switching Power Supply 100W 24V 4.5A for CNC Router Kits 115V/230V S-100-24]. Below I have attached links where you can find specifications and the data sheets for each. My question concerns the current and voltage I should apply to the NEMA 23.
    I am looking for a high torque (low speed) application, and so speed is not really concern, I care more about accuracy, so I will most likely use larger steps which can retain there intermediate positions with higher precision. Currently the Power Supply is pushing out 24V to the Driver. Here is where I am stuck. The driver has many switches and configurations for the current output. Specifically, it has a full and a half current mode and I am not sure if they are as simple as they seem. If I have the Current Mode Table to Half-Current Mode and the Current Table to 4.5A Peak, does this simply mean that the Motor Driver is pushing out half of 4.5A (2.25A) to the NEMA 23? If so, then would it be safe to switch the driver to Full-Current Mode and send the Motor 3.2A (the motor is rated for 3.5A). I know this may seem like a simple question, but there are always concerns about Back EMF and the like and I would really like to not destroy my NEMA 23 before really using it.
    I hope this makes sense and please ask me any questions you may have. Thank you so much for your time!
    Motor: High Torque Nema 23 CNC Stepper Motor 3.5A 3Nm(425oz.in) 23HS45-3504S|23HS45-3504S|Nema 23 Stepper Motors
    Driver: 2/4 phase Nema 23 Stepper Motor Driver 24-50VDC 1.5A-4.5A 256 Microstep M542T|M542T|Stepper Motor Drivers
    Supply: Switching Power Supply 100W 24V 4.5A for CNC Router Kits 115V/230V S-100-24|S-100-24|Power Supplies
    May 2005
    1397
    Re: NEMA 23 and Driver Setting Question
    Wouldn't this be a question for the people you purchased the driver from? Don't they support their customers?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Nov 2015
    6
    Half current mode halfes the current while stepper holds its position, hence reduces heating. This is usually preferable, except if you have forces acting on axis while stepper holds its position. Sorry for spelling
    Poslano sa mog LG-D802 koristeći Tapatalk
    Jul 2016
    3
    Hey @James Newton, so I actually have already asked them, but I just wanted more input from all of you here since their response was not as encompassing as I would have hoped. Thanks for your response.
    Jul 2016
    3
    Quote Originally Posted by Zork kre View Post
    No problem with the spelling, I understand the gist! Thank you.
    May 2005
    1397
    If you have issues with heating, a CPU cooler strapped to the side of the motor with some thermal paste works wonders.
  1. DIY Nema 34 setting questions
    By groc426 in forum Avid CNC
    Last Post: 06-04-2015, 06:41 PM
  2. One DQ542MA driver with two Nema 23?
    By crimar in forum Stepper Motors / Drives
    Last Post: 05-28-2015, 07:56 AM
  3. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  4. Nema 23 and uln2003 driver
    By MASNSN in forum CNC Machine Related Electronics
    Last Post: 05-26-2012, 01:41 AM
  5. The better driver for nema 23
    By MASNSN in forum Controller Cards
    Last Post: 05-24-2012, 10:22 AM
