587,324 active members*
3,470 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Which one is the IDEAL compressor for a laser cutting machine?
Results 1 to 5 of 5
    Jun 2016
    7
    Question Which one is the IDEAL compressor for a laser cutting machine?
    If money was not a problem, what compressor would you buy and why?
    Nov 2015
    371
    Re: Which one is the IDEAL compressor for a laser cutting machine?
    Something that runs quiet and cool with the right PSI for your process. A professional grade airbrush compressor could be a good choice.
    Jun 2016
    7
    How about nitrogen or CO2, can they be used with an air compressor?
    Nov 2015
    371
    Nope, air compressors are for air only.
    Jan 2010
    53
    Quote Originally Posted by speedy_j View Post
    Those would just use a flow regulator. I use a select comfort air matress air pump for my air assist pump on my 40w laser
    Robi
  1. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  2. best choice steel sheet cutting machine fiber 500w laser cutting machine
    Last Post: 07-22-2015, 08:46 AM
  3. Which Compressor Do You Use for Laser Cutting?
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2013, 06:13 PM
  4. 5'x5' Water Jet Cutting Machine Ideal for Small Shops
    By Jetedge in forum News Announcements
    Last Post: 09-07-2011, 03:15 AM
