587,982 active members*
4,720 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Cheap Ebay Stepper cable - anyone having problems with the oil and the jacketing?
Results 1 to 6 of 6
    Nov 2013
    29
    I'm looking for some shielded stepper cable for my milling machine conversion. There are inexpensive options on ebay but none seem to indicate they are oil resistant. Just wondering if anyone is having issues with cheap stepper cable reacting (cracking, etc) with coolant and way oils?
    Or conversely, anyone know where to get good deals on shielded, oil resistant cable?
    16 4 AWG Shielded Stranded Wire Cable for CNC Stepper Motor Router Control 10 Ft | eBay
    35538
    Re: Cheap Ebay Stepper cable - anyone having problems with the oil and the jacketing?
    You don't need to use shielded cables for stepper motors.
    Nov 2013
    29
    Regardless, question still holds. How important is oil resistant cable, whether shielded or unshielded? Thanks.
    1943
    That looks like the same cable sold by automation technologies. I have it on my mill and have not had any problems with exposure to oil, cutting guilds, mist coolant, etc. it is a bit stiff and I would have liked to have a little mire flexibility, but it has done fine.
    Jun 2014
    777
    alpha cable
    May 2014
    182
    You sure you need 16g?
    If those are in flexing applications, you can count on the foil shield breaking over time and losing wire coverage. This will negate the shielding. Those wires are very much meant for static applications. With a high flex rated cable, typically you will have a good amount of shielding to minimize binding of cables against each other during flex operations. The wires are usually centered as close to the neutral axis as possible to minimize overall movement. You will want a braided shield for moving applications.
    The type of shield also affects what frequencies are emitted or received by the cable shield. Typically the braided shields outperform the foil shields in all but the lowest frequencies.
    IGUS CF140US
    igus® Chainflex® continuous-flex cables: Chainflex® CF140US control cable PVC
    shielded, oil resistant, 18/4 high flex rated cable - $1.75/foot. Rated at 14amps
    Other gauges available too
    If you don't need shielded, go with the CF130US for $1.25/foot
    igus® Chainflex® continuous-flex cables: Chainflex® CF130US control cable PVC
  1. Those Considering buying the Cheap Ebay K40
    By belin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-29-2013, 03:47 PM
  2. Cheap eBay Laser
    By tjb1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-09-2013, 01:20 AM
  3. Cheap PVC CNC from ebay
    By fuflogen in forum Commercial CNC Wood Routers
    Last Post: 07-21-2013, 12:15 AM
  4. Cheap 16c collets on ebay, any good?
    By gixxergary in forum Haas Lathes
    Last Post: 11-23-2011, 12:38 AM
  5. Cheap Ebay PCB CNC machine
    By psychoul in forum PCB milling
    Last Post: 03-18-2011, 07:39 AM
