Originally Posted by
awerby
What happens if you turn the rotational soft limits off? Unless you've got a homing switch set up on the 4th axis, you can't expect it to find home, and arbitrarily limiting its motion with soft limits doesn't seem too useful. Otherwise, it might be something going on with the driver. See what happens if you turn everything off, letting the caps drain before disconnecting anything, and switch the leads from an axis that's working okay to A, putting the A axis leads to it.
