587,982 active members*
3,905 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > no probe selection on my setup screen
Results 1 to 8 of 8
    Jul 2016
    5
    hi all,
    i have recently purchased a pcnc440 and a wildhorse passive touch probe that is supposed to be preconfigured for the tormach. problem is there is no selection on my setup tab that allowes me to select what type of probe i am using. i have a sneaking idea that i have missed something simple.
    any help is appreciated.
    joe
    Jan 2012
    97
    Re: no probe selection on my setup screen
    You select the type of probe in the Settings tab. The passive probe opens on contact and the digitizing probe closes on contact.
    Jul 2016
    5
    Yes, i understand that, however the selection boxes for the different type of probes do not show on my setup tab atall.
    May 2015
    111
    I do not believe the 440 supports the active probe, just the passive probe.
    NOTE: This product is not compatible with the Tormach PCNC 440.
    31858 - Digitizing Probe
    Jul 2016
    5
    im using a passive probe,but there is nothing on the screen tomactivate it.
    May 2015
    111
    I don't think you need to activate it. If you goto the status screen you will see accessory input. If you plug your probe in and the push the probe lightly with your finger lightly it should light accessory input light.
    Do you have a probe tab?
    Jul 2016
    5
    i do have a probe tab. the light on the probe is normally off, and turns on when activated (moved off its center axis), but the light on the screen remains off.
    May 2015
    111
    If it is not triggering the Accessory Light it maybe the probe is not compatible with the PCNC 440. I would ask Wildhorse to see if they tested it with the 440.
    When I use the passive probe on my 1100 if I press the probe the accessory light comes on. I know for probing routines you must select tool 99 also. But that should not affect the light.
  1. Hoss tool probe screen
    By Rich-TX in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2015, 12:34 AM
  2. big tex probe screen set problems
    By dude_chevy in forum X3/SX3/G0619/G0463
    Last Post: 01-30-2014, 04:07 AM
  3. Lathe probe selection
    By jmw_man in forum Want To Buy...Need help!
    Last Post: 07-24-2012, 07:42 PM
  4. Probe screen issues...
    By gadget47 in forum Mach Wizards, Macros, & Addons
    Last Post: 03-05-2010, 09:09 PM
  5. Outputing Probe Info to Screen?
    By Moparmatty in forum Haas Mills
    Last Post: 06-11-2008, 03:34 PM
