588,648 active members*
6,420 visitors online*
Results 1 to 16 of 16
    Aug 2006
    6
    Another stupid question?
    Does anyone have any opinions on what is the best CAD/CAM software for a CNC milling machine? I am building a 3 axis gantry type machine driven by steppers. The motors will be controlled by Pic List "Linistepper" drive boards.
    I intend to be milling PCBs as well as nonferrous metals & plastics. Both the metals & plastics I expect to be fairly complex 3 dimensional shapes.
    I will be using a pentium based PC running XP. Cost is an issue, but getting a good package is more important than outright cost.
    Your advice would be most appreciated.
    Tony.
    Mar 2006
    1625
    there are many out there and every one will tell you the one they use is the best. How much do you want to spend.
    Aug 2006
    6
    You are so right every package is brilliant according to someone. However, I am looking for something capable of more than 3 axis (for future projects), has a reasonably intuitive interface, easy to get started with (if not to master), is accurate & not full of bugs!
    I would like to spend no more than £250.00, but I could stretch that if it really made a difference.
    Thanks for your interest & hopefully help.
    Regards,
    Tony.
    Jan 2006
    4396
    :wave: There are very few in that price range. The only 3Axis software I can suggest is BobCAD-CAM V21. Mike and I are both users of this software. He has been using it since V19 and myself since V17. It is reasonably priced for 3 Axis work but isn't a really good 4 Axis Application. I'm afraid that for what you have to spend on software, BobCAD may be your only choice. There may be something else but I don't know what.
    Try a free demo of BobCAD to see if you like it. Here is a Link to the BobCAD-CAM Forum if you have any questions about the software. You can also call Chad Clark. I deal with him when buying software and he knows how to use BCC and will answer your questions. 877-262-2231 Ext. 124
    http://216.117.147.20/bobcadsupport/forums/index.php
    www.bobcad.com
    Good Luck in your search:cheers:
    BTW: Welcome to CNC Zone
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    easy enough to use a 3 axis software such as bobcad and edit the 4 axis move , unless of coarse you planning on doing some funky 4 axis machining
    Aug 2006
    6
    Thanks for your views, I will look into "Bobcad" (I am, even now looking into Bobcad). Do you know of any other packages to compare it to, the Mach series of CNC software for instance?
    Many thanks again,
    Tony.
    Jan 2006
    4396
    Quote Originally Posted by t305100 View Post
    Many thanks again,
    Tony.
    BTW: There is no such thing as a "Stupid Question". All questions are valid to the individual.
    BCC is a Big Bang for the Buck 3 Axis Software that is why I have been using it since V17, V19, V20, and now V21. Check out the post V22 in the BobCad Forum here in the Zone. It has not been released as of yet, but will Kick Butt when it is. You could most likely get it for $500.00 U.S. Which is a sweeet deal.
    Toby D.
    Schwarzwald
    35538
    Many thanks again,
    Tony.
    Mach3 does not come with a 3D CAM package. It's basically a machine controller with some 2D CAM capability.
    Check out MeshCAM at www.meshcam.com
    Mar 2006
    1625
    one question that you need to answer is are you looking for a cad/cam for 3d drawing as well as cam or are you just looking for cam
    Quote Originally Posted by tobyaxis View Post
    i agree in this post ,
    but dude a couple of the people that i supervise , i find it incredible what they can ask me in a day
    35538
    Quote Originally Posted by dertsap View Post
    I'll second, third and fourth that.
    Aug 2006
    6
    I find that if you ask a "Stupid question" you invariably start to get some answers. However, now that I have had some questions asked back, I will try to frame my question in a more targeted manor.
    I hope that you will bear with me;
    I have a computer, Pentium running XP.
    I am about to take delivery of a 3 axis gantry type Milling machine.
    I intend to use “Linistepper” stepper drive boards as featured on the “PIC List” (open source project).
    I do not have a mechanical CAD package, so I’m open to suggestions.
    I have an EDA package including pcb CAD outputting Gerber files (it will output in about 20 different formats inc DFX, ORCAD, PCAD)
    I require to be able to mill pcbs for prototype work.
    I require to be able to create medium complexity components in either plastics or nonferrous metals.
    So, what do I need? As I see it;
    1) Connection between computer & drive boards, Printer port or USB?
    2) Mechanical Cad package (would Bobcad if the bill)?
    3) Control software (I am considering Mach 3 from ArtSoft) from PC via 2"whatever" to stepper drive boards?
    So I open it up to the experts, what do you suggest?
    Many thanks in advance for your help.
    Tony
    35538
    Pretty much all hobby level control software uses the parallel port, not USB. So that answers that question.
    If you don't need to do complicated assemblies, Alibre Xpress is a great Mechanical CAD package, and free at www.alibre.com/xpress.
    You'll also need a CAM package. Although it is possible to export .2D .dxf files from a Mechanical CAD program, and convert those to g-code with Mach3, it's not the easiest route.
    BobCAD/CAM would let you both model and do the CAM in a single package.
    Most 3D CAM packages start at $1000 and up, which is well above your budget.
    There are other options, like MeshCAM at www.meshcam.com But if you need to drill holes in your parts, it won't do it. You can also go with a 2.5D program like SheetCAM, www.sheetcam.com which may do what you need it to do.
    Mach3 is the most popular (and by far the most powerful) of the affordable control software out there.
    Jan 2006
    4396
    Sounds like your the Right Man for the job Dertsap:rainfro:
    Toby D.
    Schwarzwald
    Aug 2006
    6
    I must be missing it, but where is BobCad offered for $500?
    Tony
    35538
    Tony
    You can supposedly get it for $500, after a lot of haggling and several phone calls from their sales staff.
