0 active members*
2,920 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Hello! Does anyone have a xilog maestro for SCM Pratix S-22 S 3-axis router?
Results 1 to 15 of 15
    Apr 2016
    Where can I find XILOG maestro to install, can someone tell for 32 or 64 bits system
    Service SCM BR Guest
    Re: Hello! Does anyone have a xilog maestro for SCM Pratix S-22 S 3-axis router?
    How version you need?
    Via iPhone of the Tapatalk
    May 2016
    8
    hi there , u seem to know a lot about scm . can u please tell me how to make the machine move back to home position and drop the tool . or how to remove a tool manually . the v45 degree bit sems to be not in place and whenever i run the machine it doesnt recognize it , and freezes . even when i command it to use a different bit it still doesnt . so am assuming that removing the bit manually or making the cnc go back to home position and drop the tool will fix it . plz i need ur help . thks in a advance
    Hello dear Colleague,
    I understood that your machine stopped while performing a tool change.
    If the spindle is close to the tool magazine you need away from it manually in power or not.
    Once you are at a considerable distance you must put the machine in power and perform calibration (F5).
    When run calibration (F5) in MDI (F6), has the (F12) or Shift + F12.
    You can command the opening or closing motor.
    For this select the aperture icon + Enter + Start (Mobile Control).
    Hello, Is Ok?
    The new version is 1.00.013.1016[
    IMG]https://uploads.tapatalk-cdn.com/20161103/55c74430d894e149cec23fc8a59f6efc.jpg[/IMG]Click image for larger version.
    Nov 2016
    kris1974
    you already have the software xilog maestro? If yes then send me with. Thank you.
    Hi Luxury, I send the new version of the Xilog Maestro for you.
    https://drive.google.com/file/d/0B67...ZBMmxnSWs/view
    May 2015
    10
    Quote Originally Posted by Service SCM BR View Post
    Hi Service Scm BR
    Good day
    Is it possible to run xilog maestro by xilog3 hardlock or even without hardlock ?
    Thanks in advance
    Hi. No, this is not possibile.
    May 2015
    10
    Hu
    Where can i get maestro hardlock
    You must buy Maestro from SCM
    May 2015
    10
    I got it
    Thank you very much
    Jan 2015
    35
    Quote Originally Posted by Arion_Hyon View Post
    Good morning, I've been looking for the Xilog Maestro installer for several weeks. Could I have the new installer? If possible, in an x64 bit version since I want to put it on the new office computer.
    Thank you so much.
    If you have dongle usb key you can get new version by your dealer or you can call to scm and they will give you latest version
    Mar 2022
    Have you moved the software package for download?
    Google Drive reports file no longer exists!
  1. Replies: 3
    Last Post: 05-26-2024, 11:41 AM
  2. Z axis alphacam - Xilog plus
    By ingeniero_j in forum Alphacam
    Last Post: 06-14-2014, 06:18 PM
  3. Replies: 1
    Last Post: 01-31-2014, 04:00 AM
  4. Replies: 1
    Last Post: 04-07-2011, 12:45 PM
