587,414 active members*
3,229 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > ArtCAM 2008 strange path
    Jun 2016
    8
    Hi guys !
    I did a engraving toolpath in ArtCAM. Like you can see on picture.
    My problem is that, when machine start engraving it first goes to letter P and make a dot, than it goes to letter O and make a dot. After that it goes to some other letter and make dot.
    After all those dots been made machine goes from letter to letter and make them till the end.
    My question is : Is there any way to make toolpath engrave letter by letter (not jumping around) and moving in some logical order for example V-O-D-N-O P-O-L-J-E and not like now P (just dot) - U (just dot) and so on...?!
    Cheers
    Sep 2016
    9
    Re: ArtCAM 2008 strange path
    Hi first change the text to vector then you can make toolpath letter by letter after you finished merge all the orders together and you will be happy
    Jun 2016
    8
    Quote Originally Posted by jadmaz View Post
    Okey, that solves the problem...
    But problem is... there is 38 letters and that means that I need to make 38 toolpaths and than marge them all into one which takes a lot of time.
    Is there any more simple way to do that ?
    Sep 2016
    9
    Quote Originally Posted by Izopaceni View Post
    I have about 8 years experience in art cam i don,t know another way but you can open the toolpath give the order to the first letter leave it open select the second letter change the toolpath name to (1) for example press ok then the third same way or you can group 4 or 5 letters under 1 toolpath other way i don,t know
    Cheer
  1. sos, relieves en artcam 2008
    By melba in forum ArtCam Pro
    Last Post: 09-02-2014, 11:49 PM
  2. Need help on artcam pro 2008 version.
    By M.Abid in forum ArtCam Pro
    Last Post: 03-21-2014, 10:37 AM
  3. artcam 2010 examples to artcam 2008
    By mishu28nmv in forum ArtCam Pro
    Last Post: 06-15-2011, 06:27 PM
  4. Artcam 2008
    By Vegabond in forum ArtCam Pro
    Last Post: 06-22-2010, 02:25 AM
  5. ArtCAM Insignia 2008 now available
    By Beckyf in forum News Announcements
    Last Post: 04-02-2008, 03:12 PM
