i am new in this cnc zone forum, i create a screen set for mach3 with flash.
Visit this page for download it.
https://www.facebook.com/notes/d-diy...51044531816926
You can test it. Hopes it useful.
Thank you.
Thank you.
Nice and grey.
thank you sir.
have you try it?
Good effort. Depends on what you're trying to achieve, I guess. This logically lays out a lot of information all on one page which is great in some applications. Personally I prefer a screen that has key information for the current task up big, bold and very easy to find. High density information like this means you have to scan the screen to hunt down what you're looking for, which is often fine but in some circumstances can take too long.
thanks for you comment and suggestion.
i changed some lay out to make it easier to handle and see.
Attachment 335276
dharmic, thanks for you comment and suggestion.
Attachment 335278
Attachment 335280
Attachment 335282
Attachment 335284
you can download it here
Thank you for all the comments, here i makes some major change in the layout...
Attachment 335296
Attachment 335298
Attachment 335300
Attachment 335302
Attachment 335304
Attachment 335306
download it here
Nice Screenset!!...and if it suits your needs even better. Mach4 and UCCNC made modifying there screen really simple and when it comes to Mach3 2010 screenset nailed it IMO. Have Fun!
Thank you.
You can download for "chocolate" version here
Attachment 335312
Heaps better this time around.
I'd still lose that wall of data in the diagnostic screen and shuffle it off to a page of its own rather than repeat it everywhere. When I'm running a program I don't care about the diagnostic info. I'd much rather have a bigger DRO and toolpath preview.
I'd also try a stronger visual style for grouping data. The flat panels look is very modern and sleek but it utterly fails at visual identification of clusters of data and control. For example, you can't tell just at a glance where the Execute controls stop and the Tool Info stuff starts. A border (old fashioned) or frame of whitespace (modern) between them would help enormously.
Third tip: looking at that I can't easily tell the difference between information and what's referred to as a "call to action", ie a control which the user does something with. By styling the buttons and other controls so they are obviously different to information fields, it makes it easier to locate information AND to track hand-eye to controls by reducing the number of possible targets for each type of interaction (read vs do).
A few tips, hopefully they're of some use to you.
Otherwise it's a pretty clean looking screen. Well done.
As Flash has been turned off permanently by all major browsers for real security reasons, I would have to question the idea of using it for a new application.
I agree about the 'too much on one window' comment too.
Sorry
Cheers
Roger
While this is a tremendous effort, it's probably too late in Mach3's life to see much use.
I gave up on Flash screens about 7 years ago, when I saw that they wouldn't run on my machine control PC, and Artsoft never provided any documentation on them.
thanks for all comments and suggestions....
About "too much in one page", well...,.i'll try to re-designed all the layout to the most simplest one, and will post it soon here.
Have fun !
Looks great, will give it a try...
Here's the link:
Screenset 1
Screenset 2
Thanks.
I see.
But it remains that Flash is a huge security hole which many of us have turned off totally.
JPG is enough; we do not NEED Flash any more.
Cheers
Roger
OK, but please don't make any changes based on what I am saying because regardless how you make it, it is not for me. For a useful HMI you need to REDUCE the information dramatically. With the overloaded screen it is difficult to select relevant information and filter out the "spam", like CPU speed, load and so on... If you think it is important then fine, but I think most people dont care about that when they are using a CNC or any other machine. They just want to control (or monitor) the machine, and not necessarily everything from one screen. Your screen is simply information overflow. Some people like that sort of thing, I don't. I also prefer other color scheme, it is very difficult to read white text on gray and black background, but again, if you like that combination, it is fine. I prefer black text on light background (even light gray background is good), or text in a few other color for special purpose, but still on light background. Dark gray and black background is very good for picture framing but not very good for text.
Again, please don't change anything based on my comments unless YOU think it would improve the screen set, because I will not use it regardless how you do it, so no point doing it for me.
