588,683 active members*
6,385 visitors online*
    Jul 2016
    7
    Coolant for FogBuster?
    What type of coolant would you recommended for cutting aluminum in a FogBuster system?
    Here is what FogBuster stated: "We use Hangsterfer's S-500 CF when working with aluminum and mild steel." "Cimcool's Cimstar 3890 works well with stainless steel." "Our customers have reported that Koolmist Formula 77 is also a good all around choice." "If cost is not a major concern, Acculube LB 2000 is an excellent plant based cutting oil that does not require mixing."
    I have no experience with the aforementioned.
    Feb 2006
    7063
    Re: Coolant for FogBuster?
    Whatever you use, make sure it's safe to inhale, because you WILL be inhaling it....
    Regards,
    Ray L.
    Jun 2006
    3063
    I've used Hangsterfer S500 CF with no problems and so far as I can tell, none of it is making its way into my lungs.
    Mar 2004
    1543
    I also use the Hangsterfer S500 CF for AL and steel. works very well.
  1. Fogbuster Mount
    By scott216 in forum Tormach Personal CNC Mill
    Last Post: 12-18-2015, 05:20 PM
  2. Trico Md-1200 V/S FogBuster
    By smokediver576 in forum Tormach Personal CNC Mill
    Last Post: 08-21-2015, 02:03 AM
  3. Coolant for Fogbuster which is good for drilling Aluminum
    By X35 Design in forum Tormach Personal CNC Mill
    Last Post: 09-14-2014, 03:26 AM
  4. Anybody using a Fogbuster?
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 07-08-2013, 05:17 PM
  5. Coolant for fogbuster
    By David Da Costa in forum Benchtop Machines
    Last Post: 03-02-2010, 06:43 PM
