587,256 active members*
2,823 visitors online*
IndustryArena Forum > CAM Software > MadCAM > MadCam post process not generating tool change
Results 1 to 9 of 9
    Sep 2013
    23
    Pretty newbie here, I'm trying to post process a job with 4 toolpaths and 3 tool changes. For some reason MadCam is not generating the tool change command between toolpaths. M6? I think. When I run the simulator all looks good but when I cut air the machine just continues without the stop to allow for a bit change. The file looks like there is no command for a tool change. Recalculated a couple of times and redid the complete tool paths with same result.Any thought?
    Thanks!
    Sep 2013
    23
    Re: MadCam post process not generating tool change
    Btw I'm using 64 bit Rhino and the MadCam plugin. I run Mach 3 on my machine. I have a 3 axis Raptor.
    Sep 2013
    23
    Ok tried to watch a couple of post videos on Utube, verified that all my tools were save, checked the options box to "save each toolpath in cutter tool child layers". No Luck, I noticed that the post file states "Tool changes: not specified in post processor"
    May 2013
    261
    My machine does not use tools changes so I do not know much about it , so hopefully Dan or Joakim chimes in here soon .
    But are you sure you have the correct post prosessor selected for your machine , and you also have the option as a temp fix to place them manually until you get it solved
    Sep 2013
    23
    Thanks Gregore,
    I have 3 Axis machine and Mach3 chosen for my post processor so I think it's correct. I've created multi tool/ toolpath programs previously and its worked, I'm thinking I may have an issue with my model? The last thing I tried last night was too save all of my tools that I have created in a separate folder on my desktop. I had read a thread about permissions to the tool folder causing issues but it didn't work.
    Sep 2013
    23
    Looks like I may have figured it out. Not exactly sure but I redid the model with nothing but curves. I had a couple of curves that were not joined. then I reset the Rhino options for tolerances and the MadCam tolerances and to 8 threads. I also numbered the tools differently and set the options to nest the toolpaths. It looks like it worked so I guess I'll try and runit and see if I break that .042 bit, LOL
    May 2013
    261
    Glad you found a solution usually they the guys that are more in the know are quicker to jump in and help solve . You always have the option of emailing Joakim directly , but I think it is always better if the question can be asked publicly so answers can be here for others .
    .042 That is massive wait until you get down to .004 then we can talk about small . Make sure you double checked the speeds and feeds even if it means phoning the manufacturer . I use Harvey tool for the small cutters and they are very helpful .
    Also remember to be a little conservative on feeds and speeds if your run out is not excellent
    Apr 2003
    1357
    Sorry, I've been away for a couple of weeks. To include a toolchange in your paths there needs to be a section in your post processor. It will look something like this:
    *TOOL_CHANGE*
    N"lnbr" T"toolnr"M6 (TOOL CHANGE: "toolname")
    N"lnbr" G0"fixture_offset"
    *END_SECTION*
    Do you have a section like this?
    Dan
    Sep 2013
    23
    Thanks Dan,
    Yes a have a variation of the M6 command now.
  1. Dorian Tool SD30BXA Quick Change BXA Tool Post New Unused!
    By Contract_Pilot in forum For Sale Only
    Last Post: 06-28-2015, 12:46 AM
  2. Change the post process and add new line automatically
    By sml2010 in forum Uncategorised CAM Discussion
    Last Post: 04-25-2014, 04:34 PM
  3. Replies: 9
    Last Post: 02-21-2014, 02:55 AM
  4. Generating gcode from dxf tool path
    By outsider787 in forum Mastercam
    Last Post: 03-23-2012, 08:58 PM
  5. generating tool paths from solids
    By jderou in forum BobCad-Cam
    Last Post: 10-26-2005, 12:04 AM
