588,624 active members*
5,735 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 4th axis problem: 1 revolution = 290°
Results 1 to 9 of 9
    Aug 2015
    10
    Hi all. I recently setup a Tormach tilting 4th Axis on my series 3 PCNC 1100, and the axis is not indexing correctly. When I rotate the table one full revolution, Path Pilot indicates it has rotated only 290°! Any ideas as to what might be the problem?
    Aug 2007
    701
    Did you zero the A axis? Also you may need to be in incremental mode (G91) ? Otherwise it goes to the absolute position e.g. Starting at 70deg, a G90 A360 command will move it too 360. A G91 will move an A360 command a full revolution.
    Forgive me if you know this already.
    Aug 2015
    10
    Re: 4th axis problem: 1 revolution = 290°
    Thanks for your response Brian. I just found the problem. The new drive that controls the A-axis has a series of switches and one was in the wrong position. It's working fine now!
    Aug 2007
    701
    10-4
    Glad you fixed it!
    Jul 2015
    81
    Quote Originally Posted by brianbonedoc View Post
    Brian, Thank you! Answers like this are a great resource for those of us who did not know this already.
    Feb 2009
    281
    Quote Originally Posted by oneineight View Post
    Another little info- most CNC programs running a rotary table have a "shortest way" built in, so if you are at 20 degrees and ask it to move to 340 degrees, it will run 40 degrees backwards past zero to 340 rather than running the long way 320 degrees forward from 20 to 340
    Apr 2011
    720
    Is it possible to override that shortest way thing? Being a geared table, I would think it might be better to go the long way around because of backlash.
    Terry
    Feb 2009
    281
    Quote Originally Posted by MFchief View Post
    Terry
    In Mach 3 under GENERAL CONFIGURATION you will find a box where you can check full rotation in G0 commands or short rotation ( finding the shortest distance)
    Apr 2011
    720
    Thanks Instructor37,
    Does anyone know if PathPilot offers a similar option?
    Terry
  1. 4 Axis Revolution to 4 Axis Straight cutting.
    By 9r2a5m70 in forum MadCAM
    Last Post: 10-19-2015, 09:19 PM
  2. Recalculate Revolution Roughing
    By Jason Forbes in forum MadCAM
    Last Post: 11-22-2014, 09:45 PM
  3. Engagement of Inches Per Revolution
    By chipsahoy in forum Fanuc
    Last Post: 01-25-2010, 08:10 PM
  4. Steps per revolution
    By scrambled in forum Mach Software (ArtSoft software)
    Last Post: 12-15-2009, 07:36 AM
