here in the last week the x-axis has been starting to "run away" and faulting out quite a bit. Have checked axis lag, and all 3 are at .015. What to dianose next?
Have the baldor "big mho" motors on it.
Usually that indicates a faulty connection between the controller and the encoder related to the servo motor that's having a problem.
years ago i had a tree 320 that had the control on a pedestal mounted on top of the cabinet for the axis drive cards and the coolant/ chips being blown off the tables the pedestal allowed the coolant to drip on to the drive boards causing it to run away
otherwise i would say the same as awerby
What servo drives are you using? It sounds like one possibility is something wrong with the tach voltage output from the motor, or the wiring to the motor.
If the encoder signal is being picked up, and you can see the position display counting, the encoder is probably not suspect.
I had recently restored a Tree Journeyman 320, that uses the same motors, and the ServoDynamics 15xx servo drives. I had the same issue that you were having, so I removed the drive belt to avoid any major problems. After tracing signals and other troubleshooting I discovered a bad crimp fitting on one of the servo motors tach wires at the drive board. As soon as I re-terminated the connection everything worked with no runaway condition.
Bill
