587,481 active members*
3,017 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma floppy to usb conversion
Page 2 of 2 12
Results 21 to 38 of 38
  1. #21
    Aug 2011
    421
    Re: Okuma floppy to usb conversion
    U10L same U100L jumpers
    OSP-700L same OSP-7000L jumpers
    "Imagination is more important than knowledge."
  2. #22
    Jun 2015
    4156
    hey kurmay ! secret ?
  3. #23
    Aug 2011
    421
    It is no secret that the two people know
  4. #24
    Jun 2015
    4156
    i hope i got it right : you are Okuma
  5. #25
    Jun 2008
    113
    Does anyone have experience with floppy-ethernet emulators? Some random guy fried the board handling serial transmission of our machine a few years back and since then we have been running with a floppy in our hand to the machine and back to the computer. I would rather see our machine connected to the ethernet via the floppy emulator than run with a usb-stick to the machine and back. DNC/repair costs $7000+. Not an option right now.
  6. #26
    Jun 2015
    4156
    the link from 1st post in this thread is broken, but there is a clue ...
    please consider contacting morris midwest, maybe there is a chance
    Quality Machine Tools and Engineered Solutions - Morris Midwest
  7. #27
    Jun 2015
    4156
    Quote Originally Posted by OldOkumas View Post
    The one that worked, search for ebay #300723408804
    hey myhaje, check this out : 300723408804 | eBay
  8. #28
    Dec 2016
    4
    Quote Originally Posted by kurmay View Post
    Tried it out,with no luck.
    Must be the fact that I have the newer 3 digit display?
    Sent from my SM-N920P using Tapatalk
  9. #29
    Dec 2016
    4
    Ok, so I just recevied this:
    White 3.5 1.44MB USB SSD FLOPPY DRIVE EMULATOR E100 Version for SFR1M44U100 White 3.5" 1.44MB USB SSD FLOPPY DRIVE EMULATOR E100 Version for SFR1M44-U100 | eBay
    Tried the Jumpers at: M0, S1, JA, JB
    And also at: S1
    Still getting a disk Error
    OSP-700L Controller
    Kurmay, any Ideas???? Thanks for your help on here!
    What is it that I am missing?? all the other emulators have worked great!
    Just this **** Okuma!
  10. #30
    Oct 2015
    4
    our 1994 lb35 with osp7000 controls the floppy drive is on the way out and we want to convert to a usb stick drive . found a drive that is so called made for our machine comes on but throws a error is there parameters that need to be changed
  11. #31
    Sep 2017
    27
    Just wanted to chime in here with what worked for me. Used a 3 digit display USB, OSP-U100M on my Okuma. Had jumpers setup as instructed but was getting errors as well....found that I could view the files without issue when using MS-DOS mode.
  12. #32
    Nov 2011
    5
    if control unit is OSP7000 , you must use 4 jumpers on MO,S1,JA and JB
    if unit is U100, 2 jumpers on MO and JA
    Thanks! It's almost perfect but still need help.
    Got a grey 3 digit sfr1m44-fu and installed on a OSP-7000L lath. Stock nothing worked. Changed jumper as per Kurmay's post and it got much better. I can copy both directions in proprietary format (OSP?) and can copy files from PC to USB to lath in MS-DOS format.
    I still can't copy MS-DOS format to USB and see the files on PC. Both proprietary and MS-DOS files are copied to USB correctly (NC indicates successful copy) but then I can't see them on PC, only on NC. Not working either with folders created by PC or by the emulator drive.
    Any ideas?
  13. #33
    May 2011
    10
    Post Re: Okuma floppy to usb conversion
    Quote Originally Posted by GFerreira View Post
    Any ideas?
    I have had a unit from Gotek model SFR1M44-FEL-DL and I'm having a similar issue. If I copy a file from the PC to the USB and then try to read it on a 7000L control I see no file (this is in MSDOS mode on the control). If I then copy a file from the NC to the USB the copy says its finished and a DIR shows the file. Back at the PC I cannot see the file only the file I originally copied on the PC. So similar to what you are seeing very strange.
  14. #34
    Aug 2011
    421
    Quote Originally Posted by akl-kiwi View Post
    Filename length must be 8 chars in MSDOS mode
  15. #35
    Oct 2019
    HI Kurmay,
    Would you know the configuration on the E100 controller by chance?
  16. #36
    can someone post instructions for transferring programs from USB to control ? with the emulator ?
  17. #37
    Nov 2016
    42
    Hello there please help me
    I have bout an okuma mc4va center milling machine but it does not have floppy disk and floppy to backup the system. I want to know if I buy a floppy emulator I can able to back up all of machine data?
    Please let me know ????
  18. #38
    Nov 2022
    has anyone gotten the u10 or u100 to work with both msdos and osp on these 2 or 3 digit usb emulators?
  19. #39
    Jul 2023
    Hello,
    on Monday I installed the normal SFR1M44-U100 with 3 digits for PC use in the OSP E100L. You need 3 jumpers for MO, S0 and JA. This is the same configuration as the floppy drive and runs fine.
Page 2 of 2 12
  1. OKUMA OSP Floppy Simulator
    By kurmay in forum Okuma
    Last Post: 03-10-2024, 10:13 AM
  2. Okuma OSP7000L Floppy to USB?
    By fishtuna57 in forum Okuma
    Last Post: 07-11-2020, 04:07 PM
  3. Floppy to USB Conversion Kit
    By Laser Motion in forum News Announcements
    Last Post: 01-23-2013, 04:12 AM
  4. OKUMA OSP Floppy Reader
    By erdemkaraman in forum Okuma
    Last Post: 08-10-2011, 07:39 AM
  5. okuma floppy needed
    By cinci5 in forum Okuma
    Last Post: 03-06-2009, 02:58 AM
