Is it just me or is this definitely the case?
I recently noticed that my the contour i asked my cnc to do would not look like the contour I asked it to do.
The corners did not look like corners. They were like smoothed and rounded out. almost like if there was no corner.
Unless i lowered the feedrate to 40 IPM. So I decided to investigate.
Turns out that if I provide more Gcode lines or (more resolution) I could run it properly at that faster feedrate which was 200 ipm. else i had to run it at 40 IPM.
If this is true why is this the case? id like to understand it a bit more.
thanks!
