Ok so after playing with the Router with the original equipment I ordered a Gecko G540 and 48V power supply from Homann Designs
Started the upgrade where I plan to add correct earthing and shielded but have come up with a few questions...
#1 The OE wiring used a "Common Choke" (wire wrapped around a ferrite donut) I ordered some shielded 4-core cable from Homann also which I planned to use to run the spindle but I cannot use the Choke with this cable.. But im guessing the shielded also negates the need for the choke?
#2 Not sure how to wire up the Spindle/VFD Do I run the Earth from the Spindle and the shield from the cable to the Earth on the VFD then a cable from that point to the Earth Star or do I run the Spindle Earth & Shield straight to the Earth Star and a cable from the VFD earth to the Star... or maybe another way? This pic should help explain...
#3 Expanding on that, Ive read a few sources that say to earth the shielding at both ends of a spindle supply cable? but things like Steppers and limit switches only at one end.
#4 The original wiring to the power supply had the "Live" from the mains connected to the "N" on the power supply and the "Neutral" from the mains connected to the "L" on the power supply... Which is ass about??? But im guessing being AC power it wouldn't really matter which way it runs? Ditto on the VFD AC power supply in?
#5 I was reading the Gecko Manual and it says "CAUTION! Never put a switch on the DC side of the power supply! This will damage, if not destroy, your drive due to a current inrush when the switch is first thrown"
The OE wiring had a switch between the Power supply V+Out and the controller V+In... Which Im thinking Ill have to Delete and I would be best to wire the switch in between the Mains "L" and power supply "L" or would it be better to wire it between the "N"
