I make Embossing dies out of 7 mm Magnesium Alloy. They are not bigger than 150mm x 100mm.
For my roughening, I use a 3 mm router bit. 5 mm deep with an offset of 0.4 mm.
And for finishing I use a 6 mm x 60 Deg V-bit 1.5 mm deep. To save time, I use the "Use Flat Area Clearance tool" function and add my 3 mm bit to it.
This will create "chamfered edges" on the artwork. Attachment 185784
My problem is that I have a border around the artwork that I'm machining, now the finishing tool goes and machines the border as well. (I cut the die out off the stock using Profile toolpath)
I want to know if there is any other way to prevent it from machining the border.
See Picture Attachment 185780 V-Bit is the Purple tool path.Attachment 185782
This extra toolpath on the border is wasting time, how can I remove it without editing my cnc* file.
or
is there any other similar software that will help?
