588,204 active members*
3,846 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > G41 in V29 Advanced Z level finish
Results 1 to 5 of 5
    Apr 2016
    102
    Guys
    I am trying to use G41 cutter compensation for the first time but it does not seem to be present in the wizards. I am using V29 Mill Pro.
    I can tell I am making a school boy error here but I cannot figure it out, any help gratefully received.
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Dec 2011
    361
    Re: G41 in V29 Advanced Z level finish
    Bazzer,
    The software does not support outputting 3x Cutter comp. If you are using it to finish a flat wall, then you will need to use profile rough or profile finish.
    Apr 2016
    102
    Quote Originally Posted by SeanDa View Post
    Bazzer,
    Hello Sean
    Thanks for your reply and this clears the question up.
    The part has a 3D feature that morphs into a 2D feature that has to be matched to the same 2D feature on the end of a bar, cutter comp would have been useful to assist the matching but we got it done anyway.
    Baz
    Feb 2017
    32
    Full 3D is kinda like 5D and really could not use cutter comp, because a lot of the cutting is done with a ball nose end mill. Unless things have been improved now with very high end software or machine controllers.
    Dec 2011
    361
    Macro,
    Some controls do support 3,4, and 5 axis tool compensation.
  1. Replies: 1
    Last Post: 02-29-2016, 01:26 AM
  2. Replies: 0
    Last Post: 02-26-2016, 06:53 PM
  3. Z Level Rough Vs Z Level Finish
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-19-2016, 03:37 AM
  4. Z level finish, wont finish bottom of feature
    By jay_dizzle in forum BobCad-Cam
    Last Post: 10-02-2015, 04:49 PM
  5. Advanced Z Level Finish
    Last Post: 01-30-2015, 11:49 PM
