587,999 active members*
2,337 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > IDC B8001 servodrive manual request
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Aug 2015
    6
    Re: IDC B8001 servodrive manual request
    I tried that and it still didn't work. I had the *.mtr file from the old drive and uploaded it to the new drive and still no luck.
    Finally I struggled for a week together with the application engineer from Kollmorgen application engineer to configure their latest AKD drive and yesterday finally succeeded!!
    Kind of embarrassing for such a simple application with only analog control voltage and drive enable signal used to run a brushless motor at 4800rpm,
    we had to use drive with 1337 page user guide and a 212 page installation manual!!!
    Although marketing flyers advertise "One button tuning" and simple configuration in practice its always a different story!!
    Thanks Mike for your reply.
  2. #22
    Feb 2015
    4
    2 years later, Similar problem. Different Machine: 2 Yrs ago i gave up on the B8001 and got an AKD-B00606-NBAN-0000. the motor on this machine is AKM42G-EKCN2-00. Using Workbench configuring and getting the machine running was a piece of cake. Now, on a similar machine, i got rid of the B8001 wihout wasting time and got an AKD Drive. Problem? the motor is IDC G34VI-b32-0100-v. Wired everything and got a motor file for a B32 motor from Kollmorgen. Problem now it will enable ok, as soon as i touch the shaft it faults out on foldback. the motor goes to 10 amps. I put the old B8001 and it runs for 2-4 hours then it faults out on step mismatch (reason i'm trying to get rid of it). Any ideas are appreciated. So Far i've tried swaping S and T on the halls, swapping Enc A for B and B for A. Checked all my wiring about 10 times. I havent tried to swap the new AKD with the other that has been running for the past 2 years. I apologize in advance if this post is off-topic on this thread. Any help is appreciated.
  3. #23
    Sep 2010
    1765
    Quote Originally Posted by el_gotico View Post
    yep, motor phase vs feedbacks is wrong. I do not thinkn the automatic phasing routine works to change the halls around, but you can try it: it is under the feedback 1 tab. but you can get proper hall sequence from kollmorgen for the motor and then WATCH the halls switch on feedback 1 page and change them until you get them right. I suggest until you get control you set currents max on LIMITS page to 3 amps or so.
Page 2 of 2 12
  1. Manual request Fanuc A20B-0004-017
    By markder13 in forum Uncategorised MetalWorking Machines
    Last Post: 12-27-2013, 02:20 PM
  2. Replies: 3
    Last Post: 05-22-2013, 05:59 PM
  3. Milltronics Centurion 1 manual request.
    By i_fab2 in forum Machinery Manuals / Brochures
    Last Post: 04-13-2013, 02:37 AM
  4. Request for Manual for CM120 laser cutter/engraver
    By surfsen in forum Machinery Manuals / Brochures
    Last Post: 10-01-2011, 08:10 AM
  5. manual request
    By MysticMonkey in forum Okuma
    Last Post: 11-25-2009, 10:57 AM
