587,478 active members*
3,288 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 15M Parameters 9000 how to enter?
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Aug 2011
    2517
    Re: FANUC 15M Parameters 9000 how to enter?
    just to add, if you only have a hard copy you can first punch the parameters as-is then edit the file with any text editor just changing the 9000-series numbers to what your machine needs. then save the file and read it back into the machine through the serial port.
    note this works for ANY Fanuc control except the very latest 31i/32i etc
  2. #22
    Apr 2009
    1379
    fordav11, to my knowledge the param 8000 trick only works on the 15A.
  3. #23
    Aug 2011
    2517
    Yes, I'm aware the 8000 PWE parameter is specific to the 15-series.
    I'm specifically referring to punching parameters, edit file adding options, and then read parameters back into machine.
  4. #24
    Jan 2015
    3
    sorry, do you have all the parameters of FANUC 15. may I ask hardcopy pdf document. I ask for help because I have lost my documents .. please share
    sorry thank you for your help
  5. #25
    Mar 2016
    Do u still have the secret code?
  6. #26
    Apr 2017
    4
    Hi, i have a 15T, may i ask for the parameters to. I can`t find the parameters for COUNTER and KEEP RELAY.
    Where do i have to input the parameters for Timer (Sub24)?
    Tnx, best regards,
    Daniel
  7. #27
    Apr 2017
    4
    hi, i have a 15T model, could you please send me the backup. i wont to compare the parameters and see what i am doing wrong.
    Tnx a lot.
    Daniel
  8. #28
    Mar 2012
    Hi
    I am using fanuc 15M and i cant key in optinoal parameter in ipl mode
    Please send me the procedure to key in optional parameters if any one have it
  9. #29
    Sep 2019
    Quote Originally Posted by Mitsui Seiki View Post
    I have a backup of parameters,pitch,etc. for my 15M at work.Maybe you can used those.You transfer them to the machine the same way you transfer programs.And I don't think you need a password.I know I don't.
    What is solution ??
  10. #30
    Hello, I’m having the same problem, We are stuck at the IPL, we lost power to controller when the batteries went dead. Not sure if we need password. Can any one help with this? Thank you.
  11. #31
    Apr 2009
    1379
    You will need a a backup of the NC and PMC parameters as a minimum. Do you have these? You can send an email to me at [email protected]
  12. #32
    Sep 2020
    7
    Quote Originally Posted by posedi View Post
    Dear all!
    Recently I had ram parity error (base0) error on this machine. Battery was never changed so memory was cleared and I lost all the parameters! Therefore, I cleared all the memory and I entered again by hand all the parameters. Machine started now without alarm but I cannot enter parameters from 9000-9020, 9100-9139. This parameters are important because number of axes are stored there etc. Now I have number of axes by default: 1, so I can drive only one axe )
    I called Fanuc guy and he said that it requires a password for this parameteres. What kind of password?? Where to enter?
    Also, on papers I found some timers and I entered them also. What about counter, keeprly, Data table data? Does anyone knows how looks like printout of this additional parameters? What else I have to enter in the machine, what to take care of?
    Thank you very much!
    I have same problem with my machine
    Please send me how to solve it
    [email protected]
  13. #33
    Apr 2009
    1379
    email me at [email protected]
Page 2 of 2 12
  1. Replies: 23
    Last Post: 07-26-2023, 12:43 PM
  2. fanuc ot-a pmc parameters wont enter
    By Delw in forum Fanuc
    Last Post: 10-28-2021, 10:03 AM
  3. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  4. Fanuc 0M Parameters 9000-9899 description
    By nik_chris in forum Fanuc
    Last Post: 10-02-2019, 06:33 PM
  5. Replies: 2
    Last Post: 02-15-2007, 03:10 AM
