588,400 active members*
4,913 visitors online*
Results 1 to 17 of 17
    Mar 2017
    116
    Servo motor brake
    Hi guys,
    I have external brake on my servo motor. It has 3 pins. 24v+ , ground and pe for the housing. It required 24v DC.
    And on the servo driver cn1 connection there is BRK+& BRK-
    Right now the shaft on the motor does not turn as I do not have 24V DC connected to it.
    1)Is my understanding right that if I connect 24v to the motor brake it will release the brake and the shaft can turn?
    2_ My understanding right that brk+, brk - ,can control the on off , of the brake?
    3) Can I leave brk+ and brk - alone for now and just have 24V dc connected all the time to the motor while i do testing procedures.
    appreciate your help. so far all my questions get answered and i do appreciate.
    Dec 2013
    5722
    Re: Servo motor brake
    1) Yes, 2) Yes, 3) Yes
    Mar 2017
    116
    You know Jim, i wish i asked this before because i ran without connecting 24v to the break and instantly the driver overloaded and stopped with alarm code overload. Thanksfully the alarm code is off and servo enable green light is on but I am anxious to see if I have caused damage.
    I am waiting for my 24V DC power supply. I have tried to googledimage brk + & brk- because I want to know how you wire this. The manfacturer said that you have to put a relay in there. Is it basically just a on and off switch:
    Dec 2003
    24220
    These brakes are continuous rated usually, what you need to do also is wire a BEMF diode across the coil, otherwise you will get a large spike that could cause problems.
    The cathode to +DC side.
    Also saves the relay contact also.
    You should get away with a 1N4007.
    Al.
    Albert E.
    Mar 2017
    116
    Al.
    I will get a few of the 1N4007.Can you recommend the relay coil for the brk +, brk - please?
    Dec 2003
    24220
    The Omron LY2-DC24 style are popular, but any that satisfy the coil voltage and brake current will normally work, also if the relay does not come with it, a diode across its coil is usually needed.
    What is the resistance of the brake?
    Al.
    Albert E.
    Mar 2017
    116
    Al.
    I will purchase these: RS are in uk and do next day delivery, thank you.
    The brake resistance is: Still waiting to hear back from the seller.
    Also please see picture attached from manual and my own picture.
    In manual it says put fly diode on brake motor side but it shows relay contact on
    driver side for pins 30 + 31
    So it is treated seperatley? Never connect pin 30, 31 to the motor brake pins 1, 2, 3? Two separate circuits?
    By the way, brake voltage and current is : 24V DC 0.64 amp.
    http://maxcdn.cnczone.com/images/attach/jpg.gif
    Dec 2003
    24220
    Wired like this, both for Brake and the relay coil, wired close to each.
    Al.
    Albert E.
    Mar 2017
    116
    What about like this?
    Says in manual: "order to improve breaking effect and response, a fly-wheel diode may be added at both ends of brake coil. Pay attention to positive and negative poles of diodes"
    Dec 2003
    24220
    Not really, it does not suppress the BEMF, the diode has to go across the coil as shown in post #8.
    Al.
    Albert E.
    Jun 2003
    866
    I don't understand the in-line diodes at all.
    Dec 2003
    24220
    Quote Originally Posted by unterhaus View Post
    I think the OP misunderstood this statement::
    "Says in manual: "order to improve breaking effect and response, a fly-wheel diode may be added at both ends of brake coil. Pay attention to positive and negative poles of diodes"
    They should have said Across the Coil instead of both ends as I see it.
    Al.
    Albert E.
    Mar 2017
    116
    @ unterhaus. don't be following any of my elec diagrams. and yes the manual did not say "across" It said added at both ends.
    Please find another pic i got from a manual. I am confused. I can wire both diagrams but what is the line connecting them together?
    I got a email response from the seller saying " You should provide Relay by yourself, the purchase is to solve the larger current of the brake coil , to switch the brake control to relay control."
    From this I assume now that the relay has to handle 0.65amps. But there is no 0.65amps coming out of the servo driver. The 0.65amp is coming from the servo motor brake so am I right in thinking there is only one big circuit to build and not 2 separate ones?
    Dec 2003
    24220
    The circled line is just shows the fact that the contact to switch the brake is part of the relay, IOW one unit and not a physical link..
    Also there should be a diode across the brake coil.
    You require 24vdc for the brake coil.
    Al.
    Albert E.
    Mar 2017
    116
    If only ONE circuit and 24v required for brake then why does it say 12v for bk+.?
    I am powering servo drive connections with 12v dc.
    i will draw a diagram how i am wiring the servo. please wait.
    Mar 2017
    116
    Dec 2003
    24220
    I presume the 12+ marked brake, is for the brake relay.
    The output is a small opto isolator and is not sufficient anyway to pick up a Brake, regardless of voltage.
    The opto picks up a small relay which is then capable of picking up the brake, which in this case is 24vdc.
    Al.
    Albert E.
  1. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  2. ADtech servo drives and motors with brake
    By kamransabir777 in forum Servo Motors / Drives
    Last Post: 08-25-2015, 09:56 PM
  3. electrocraft servo E726 with RENCO encoder and brake
    By SwampDonkey in forum For Sale Only
    Last Post: 05-31-2014, 05:21 AM
  4. DC Gear motor and power off brake(on the load side not on motor)
    By glomagno in forum Mechanical Calculations/Engineering Design
    Last Post: 04-10-2014, 05:41 AM
  5. Z AXIS MOTOR WITH BRAKE
    By Russ Shugg in forum Servo Drives
    Last Post: 10-26-2009, 08:45 PM
