Originally Posted by
JackBerkhout
Hi Dan,
today, the spindle kept spinning on the end of the job, the button M3 button indicated off, as it should. Toggling it on and off switched the spindle off.
I guess, chance this can happen is about 1% or less, I have seen it once before.
You do sent commands several times at spindle start, right? Is this also the case after switching off?
To make sure the spindle works at the beginning of a job, I manually start it, for now.
I'm using UCCNC 1.2037, HY10, Windows 10, and original USB-RS485 converter, using shielded twisted pair, not too long in length.
I'm very satisfied with your plugin!
Kind regards,
Jack.
