587,380 active members*
3,863 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > converting a sherline 5000 to cnc
Results 1 to 6 of 6
    Feb 2006
    7
    Hi everibody
    I am new to this forum and I read a lot of your posts.
    I am attempting to convert a sherline 5000 mill to cnc
    I have the controller(xylotex),the steppers,and the software(mach3)
    I must say it is a great combination I have already tested the
    cnc setup with the motors not hooked up to the mill and it is working
    like a charm.
    next step is hooking the motors to the mill.
    I will keep you informed on how I am doing.
    :cheers:
    Nov 2005
    5
    sherline conversion
    Hows the conversion going so far?
    What stepper motors are you using. Is it the 269oz
    Cheers
    Feb 2006
    12
    I have the same setup on my sherline 2000 mill. It works quite well.
    Nov 2005
    5
    what sort of travel speed do you get on the x-z axis on the Sherline 2000? ( IPM on average)
    Cheers
    Feb 2006
    12
    I run around 15ipm. I could get more, but I run it pretty tight to keep the backlash down to a minimum and don't want to risk missing steps.
    Feb 2006
    7
    My mill is finished and i must say I am impressed with the machine.
    I did a couple of tests at 10 ipm and the precision is good.
    I used it mainly for engraving so far I engrave 1/2" letters and getting good results I will try smaller when I get the cutters.
    One thing I have problems with is getting single line fonts
    I use corel to export hpgl then I convert it to g-code but always have 2 lines
    I understand that TTF needs to be closed path.
    I would like some ideas if you got some.
