Again with this crusade... Just call it the gantry. If you're setting the CAM up that the material gets loaded from the front, then the gantry is the X axis.
Yet most every person that builds with t-slot extrusions somehow manages to mount the linear rails! Besides, using plate would be redundant - you'd just get thick plate and forego the extrusion. Unfortunately, with a set budget, purchasing plate and having it machined can be costly for two gantry risers, let alone two long table sides.Mounting linear rails directly on T-Slotted extrusions can be a challenge at times. Depending upon the combination of rails, extrusions, nuts and so forth getting the two rails parallel can be a real challenge. Some guys have resorted to bolting aluminum plates to the extrusions to make this easier (the rails get bolted to the intermediate plate).
The Z axis stroke shouldn't be a problem. If it was it would simply be a matter of adjusting the position of the spindle up or down in the clamp as needs warrant. As to the long axis rails (which are labeled Y) I really don't see issue here; pretty standard for t-slot extrusion build.My biggest concerns are the Z axis stroke and the way the X axis rail extrusions are coupled together with the rest of the table.
