I will definitely add the limit switches and miscellaneous components. Love doing a complete CAD before building things; helps me check EVERYTHING (probably at the cost of the learning you get from failures though).
Electronics: I am going with 2 steppers simply because that was the easiest approach I imagined. Time to explore servos now then! Any servos you can recommend as a substitute for both steppers together?
Thanks for all the feedback guys. I've made one more change -- moving the rails onto the top (instead of side) of the extrusions on the Y/long axis, to help with alignment.
Theoretical question about Z-axis (I should probably post this in another category of the forum?):
If you were given only two linear bearing blocks (for the profile rail type, like Hiwin HGH-15 type) for the Z-axis, would you put them vertically on a single rail, or would you split them into one for each of two rails? I know four is ideal, but just wondering about the mechanics in this imaginary scenario that might pop up in the future when I want to maximize travel.
wizard, The variety of comments has certainly helped, thanks to all including you and Louie for contributing your own takes.
