587,684 active members*
3,056 visitors online*
Results 1 to 7 of 7
    May 2016
    8
    Fanuc serial interface
    Hi, does anyone have documentation on the Fanuc serial interface 2 to plug in a linear scale encoder. Protocol Is that the RS232?
    Feb 2008
    644
    Re: Fanuc serial interface
    Quote Originally Posted by Shukman View Post
    I'm familiar with the serial interface 1, its a proprietary RS-422 (separate TX and RX differential pairs) interface with a outgoing request pulse and 77 incoming bits of data with 5 CRC bits at a 1.024 mbits/sec
    Pretty sure the type 2 interface is RS-485 (single differential pair for TX and RX) at a 2.048 mbits/sec rate but have not made an interface for it yet so not sure
    Oct 2012
    40
    Hi
    Why are you going for RS232C, I have a better option to skip this. I have a device where you can connect usb pen drive to machine. With this device you can transfer and received data like program, parameters, tool data etc... The device is very compact and user-friendly. It has 4 gb internal memory to store or run the program up to 4 gb. It has 2.5" Lcd screen.
    For more details please visit@
    protecdncsystems.com
    Sent from my vivo Y27L using Tapatalk
    Oct 2012
    40
    Hi
    May 2016
    8
    I have found an information on the interface in the documentation for the encoders. How can I generate a request signal. What is the data transfer rate of the interface and the number of data bits. Are there any start bits, parity bits, and stop bits in the request?Click image for larger version.
    Feb 2008
    644
    As I said for type1 the data rate is 1.024 mbits/second, the number of bits is 77 (including 5 CRC bits)
    so its not like a standard 8 bit Async serial data stream at all.
    for type 1 the request is just a single pulse, Not sure about type2 except type 2 is half duplex (single pair)
    Which Fanuc controller do you have? Fanuc has desinated connectors in the controller to talk to these scales. You have to set a parameter bit in the controller before the controller can look at the scale.
  1. Heidenhain TNC-360 Serial interface problem
    By MSFAB in forum DNC Problems and Solutions
    Last Post: 05-06-2018, 01:08 PM
  2. Fanuc 11M serial interface card
    By greenery_fr in forum Fanuc
    Last Post: 03-23-2009, 02:57 PM
  3. Serial Interface
    By foruforewer in forum CNC Machine Related Electronics
    Last Post: 03-13-2008, 08:37 PM
  4. Serial Interface Board
    By fastnovacrash in forum Controller Cards
    Last Post: 02-12-2008, 11:34 PM
  5. simple serial interface
    By mwalach in forum DNC Problems and Solutions
    Last Post: 03-24-2006, 10:30 PM
