Well, after hours of updates, I have let my system update win 10 to current. Build 1703 I think.
It is stable when I am on laptop battery power only, or when I am plugged into 120vAC power away from the machines tap. When I plug back into the same feed that is running to the machine, as with my initial setup, the error pops and the PC crashes and reboots.
It will be a real pain to run a separate AC line to my PC, before that, it seems I need to figure out what the assumed spike is, and smooth it as much as possible. I will install a quench arc on the contactor without, get my hands on a USB isolator for good measure, and look into a scope to further diagnose where the spike is originating.
Please advise if my initialization is out of order or problematic if possible.
Regarding the USB isolator. any suggestions on a solid brand, specs, or model? Does it affect the length of cable between kflop and pc (I am at 2M)?
Thanks to all.
