603,337 active members*
3,930 visitors online*
IndustryArena Forum > Other Machines > Machine Created Art > Best 3D Foam Finishes and Hard Coat Materials
Results 1 to 5 of 5
    Jul 2017
    23
    Hello! I am looking for some advice on the best types of foam finishes and hard coat materials to use for 3D foam sculptures and props.
    In your experience, what are the best types of materials for finishing foam props? (Polyurea, Epoxy, etc.)
    Also, what type of foam do you recommend using for 3D sculptures (Density, Type, etc.), and what type of materials have you found work best to finish / hard coat them?
    I would appreciate any insights or advice that you have. Thanks in advance!
    Apr 2004
    5948
    Re: Best 3D Foam Finishes and Hard Coat Materials
    I've had best luck carving rigid urethane foams. It makes a big mess, and the dust sticks to everything (think static cling on steroids). But it carves cleaner than styrene-based foam, and you don't get tear-out like beadboard gives you. The denser foams are easier to work with, more structural, and hold better detail, but the lighter ones are cheaper, so you need to balance these factors based on the individual project.
    You can coat urethane with epoxy, but it's expensive, messy and difficult to clean up. If you're trying to make a rigid shell you're peeling off the foam (like a boat or something) then you can use glass or other fibers to reinforce it. But if you're just making props out of foam and you want to firm up the surface so you can paint it, an acrylic emulsion works fine, and it's a lot easier to deal with as well as being cheaper. I've used this stuff successfully: Steve's Foam Coat
    Andrew Werby
    Website
    Jul 2017
    23
    Quote Originally Posted by awerby View Post
    Awerby, thanks for the comment! We've got a pretty hard core dust collection system, so hopefully that will help with the urethane foams.
    I haven't researched much about acrylic emulsion coatings, but I'm going to look into it now. I'll check out that Steve's Foam Coat - thanks so much for the recommendation. Really appreciate it.
    Jul 2017
    23
    The majority of the people that I have spoken to have recommended either Polyurea or Epoxy coating for our foam projects.
    Does anyone have any recommendations for brands for either of these coating types? Or any recommendations for spray systems for applying them?
    Thanks in advance!
    Mar 2016
    Hello, I would like to know how you are doing on the cnc foam carving.
    I am looking for someone that could do something that my small mill just cant handle.
  1. Hard Coat Applicator for EPS
    By TomHay in forum News Announcements
    Last Post: 10-28-2011, 01:12 PM
  2. How to coat a foam sign
    By SigUser in forum Signmaking Topics
    Last Post: 05-28-2011, 03:58 AM
  3. Special considerations for cutting very hard materials?
    By ksanalytical in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2010, 02:34 PM
  4. Tips about best adhesives and finishes for foam?
    By boggyplanet in forum CNC Wire Foam Cutter Machines
    Last Post: 09-09-2007, 03:38 PM
  5. I'm looking for someone to cut and coat custom foam parts
    By decor designer in forum RFQ Feedback
    Last Post: 08-21-2006, 11:44 PM
