If this is only a recent problem, you might want to hunt down the cause of the slop. Maybe adjust belts, tighten things up a bit. It's only going to get worse if you don't address it IMHO. Otherwise if it's a delay in the power turning on before motion begins, and if your machine uses G-code, a short 50-100 ms dwell after the power on command might help.
