588,329 active members*
4,742 visitors online*
Results 1 to 3 of 3
    May 2013
    17
    Planning to upgrade my 6040
    I'd like to upgrade the electronics on my 6040, which is a slightly older version of the omnio X6-1500GT (so I will also be adding limit switches). I think I've narrowed it down to two options, but I'm not sure which would be best.
    Option 1: Leadshine MX3660 and a UC400ETH.
    Option 2: Gecko G540 and UC400ETH.
    I'm using Mach 3 now, but might try/switch to UCCNC.
    Eventually, I'll probably buy the NEMA 23 steppers that CNC Router Parts sells and a few years later upgrade to their 2'x4' CRP2448 kit.
    35538
    Re: Planning to upgrade my 6040
    If you have room, a UC300ETH gives more options, should you need them in the future, and is only about $20 more.
    May 2013
    17
    Thanks for that, I started looking at the UC300ETH based on your suggestion and it seems like a better option, so I will go with that controller. The UB1 motherboard for it looks nice but may be overkill for me. I'll probably be fine with the 5LPT + 5axis BOB.
  1. 6040 Router Upgrade
    By hive8 in forum Chinese Machines
    Last Post: 08-30-2022, 03:39 PM
  2. Planning to start with 6040
    By Udo_Baumgart in forum Chinese Machines
    Last Post: 11-20-2017, 03:52 PM
  3. Extend Z Axis upgrade on CNC 6040
    By rjmatseer in forum Chinese Machines
    Last Post: 07-31-2017, 09:04 AM
  4. Need input! Planning my first - Basic with Upgrade path
    By Sunkmail in forum DIY CNC Router Table Machines
    Last Post: 12-22-2015, 07:48 PM
  5. Rotation axis upgrade for 6040 router
    By itain in forum Chinese Machines
    Last Post: 10-16-2013, 03:00 PM
