I got a 3040T when plugged in to 'X' Axis to 'X' Port it don't work but if I plug 'X' into 'A' Port its showing in MACH3 as working fine.
Any Ideas what's wrong.. I believe all settings are correct
Thank You
Thank You
Did you get it working?
I just got a 3040T and had a similar problem. I had to take the control box apart and chase it through. Turned out the X servo driver was plugged into the A port on the BOB and the A port was connected to different printer port pins than given in any of the 'documentation' that I could find
Simon
thanks m8 im running it through a port with no problems that i can see
I also have a problem with my 3040t the X-Axis won't move with Mach3. It just sits there and makes a grinding sound. You can move it with the knob on the Nema Stepper Motor. Could it be the Trapizoidal screw nut? Please help!
Thanks,
Tom Megna
