587,175 active members*
2,934 visitors online*
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    Sep 2017
    139
    Re: Misubishi Meldas Lost parameters
    It is easy to change L and R parameters from Diagnosis ==> PLC IF screen. No need to make any changes in ladder
  2. #42
    Mar 2008
    169
    Oh I know, I don't want to edit the ladder for parameter changing. I want print the ladder so I can study it at home. Please tell me how I load the data in the PLC IF page
    Thank you
    Carlos Cabrera
  3. #43
    Sep 2017
    139
    In PLC IF page, you find at the bottom side as below
    DEVICE DATA MODE
    In device you need to enter your L or R bit number. Once you enter the details in Device and press input on keyboard, the particular L/R bit details will be displayed on screen.
    To force/change the value of L/R bit, you have to enter the value in data and in mode you need to enter 2
    For example if I need to change by L007F to 1, then
    DEVICE DATA MODE
    (L007F) ( 1) ( 2)
    In screen, you will observe as below, if successfully changed
    76543210
    L0078 1xxxxxxxx
  4. #44
    Mar 2008
    169
    That procedure is for Forcing any address. I did that with R1900 data but when I poweron again the cnc, the data changes to the original value.
    Carlos Cabrera
    Ps: Thanks so much for your help
  5. #45
    Jan 2019
    i have Mitsubishi meldas 64 controll on multispindle drilling machine,
    because of dead battery , i lost its parameters which were not saved ,
    can you provide me its parameters ,
    thanks for your help,
    regards,
    m.yousaf
  6. #46
    Jan 2019
    regards,
    m.yousaf
  7. #47
    Feb 2005
    28
    Hello to All Friends
    I need your help
    I have a hartford machining center, whitch work with meldas magic64.
    I need system floppys
    Meldas magic64 nc system disk 1 and 2
    Meldas magic utility disk 1 and 2
    Meldas magic meldasmagic monitor disk 1
    Meldas magic custom API library runtime disk 1 and 2
    Meldas magic64 NC data 64m disk 1
    Please help me
    If u have these floppy's please send me a soft copy
    My email. [email protected]
    Thanks in advance
  8. #48
    Jan 2022
    3
    what does that even mean.............
  9. #49
    Feb 2005
    28
    Mitsubishi Meldas Magic64 PC Based
    System SoftWare Disk
    AOMEI complete disk image
    https://drive.google.com/drive/mobile/folders/1ENcGRNDRlsExITohcSXAEkZUd5pFOblP?usp=sharing
  10. #50
    Oct 2023
    9
    Re: Meldas 320 parameters
    Please, give me the parameter meldas 320M
Page 3 of 3 123
  1. Need Mitsubishi Meldas 320' parameters for Cincom L16
    By Nickon59 in forum Mitsubishi controls
    Last Post: 10-03-2023, 05:06 PM
  2. OKK MCV-300 , Meldas 84, parameters
    By Nymisis in forum OKK
    Last Post: 10-03-2023, 05:01 PM
  3. Meldas Leadwell MCV-550 lost parameters
    By fresko in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2019, 05:19 AM
  4. Mighty Viper VT-8 Mitsubishi Meldas 64L Control Lost Parameters
    By 2kjettaguy in forum Mitsubishi controls
    Last Post: 04-25-2013, 10:38 PM
  5. Meldas 625m control parameters
    By otanica in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-29-2011, 02:35 AM
