587,998 active members*
2,404 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > MC60 treadmill motor - eliminating zero speed start
Results 1 to 8 of 8
    Jan 2009
    6
    I have developed a simple way to bypass the MC60 motor controller requiring returning to zero speed before starting.
    Simply place a 100uF/50v cap between the black and white terminals with the negative leg on the black.
    The cap acts as a temporary short, simulating turning the speed to zero. Now you can set the speed, turn it off, turn it back on without changing the speed setting.
    My next project is to control the MC60 from a 0-10v spindle speed signal like from Mach3. I have the parts, just have to build it and test it. It is an opto isolated linear amplifier taking 0-10V signal from a paralell break out up to 0-18.8v expected on the potentiometer wiper input on the MC60 controller.
    Dec 2003
    24220
    Re: MC60 treadmill motor - eliminating zero speed start
    That has been solved for a while now by taking out R19.
    Al.
    Albert E.
    1943
    So, for you guys that know a lot more than me....
    I have been using a MC-60 for a while now in stock form, needing to turn the pot to 0 to start. It would be nice to not have to do this every time and be able to restart at the previous rpm. However I have a question. When you start this way does the controller do any kind of ramping when it starts, or is it like an old router where, bam!, it goes to the set rpm immediately?
    Also, how do you turn it off? Do you just put a switch inbetween the wiper leg of the pot and the board?
    Dec 2003
    24220
    If you power on/off from the supply input it will ramp up.
    Al.
    Albert E.
    1943
    Thanks Al. That is simpler than I though.
    Jan 2009
    6
    Ramps up
    - - - Updated - - -
    Thanks. My multitude of searches did not reveal this!
    Jan 2009
    6
    Al.
    do you know the physical location of r19 on the board. I have the upgraded version.
    Dec 2003
    24220
    I only know the through-hole resistor version, R19 is right next to the Pot terminals and is 15k.
    Al.
    Albert E.
  1. choosing the right speed controller for my treadmill motor/spindle
    By shiv15uk63 in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2016, 04:26 AM
  2. Motor controller won't start at slow speed.
    By Galane in forum CNC Machine Related Electronics
    Last Post: 07-24-2015, 03:07 AM
  3. DC Motor Controller & Driver 2hp ( 2kW ) Treadmill Motor
    By hesham morsy in forum Open Source Controller Boards
    Last Post: 01-27-2014, 12:50 PM
  4. 7x treadmill motor and speed controller conversion
    By maxboostbusa in forum Mini Lathe
    Last Post: 01-15-2014, 11:28 PM
  5. Replies: 1
    Last Post: 03-06-2013, 05:19 AM
