588,662 active members*
5,272 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-M Alarms #1006 and #409 on crt
    Apr 2010
    Need Help!!!
    When giving machine control any spindle command,
    We are getting alarms #1006 and #409 on crt and alarm 12 on Spindle Amplifier module # A06B-6088-H215#H500
    Re: Fanuc O-M Alarms #1006 and #409 on crt
    This is a common alarm for spindle amps. If your motor and motor power cable meg fine the issue is with the spindle amp. Check out our website, www.tristarcnc.com for pricing.
    Apr 2010
    I do not have a meg meter to check with, so I disconnected the U , V , W , wires from the spindle amp and gave it only an S1500 command and still got the same alarms.
    Would this indicate issues are with the A06B-6088-H215#H500 Spindle Amplifier Module and not the cable or spindle motor?
    The problem is within the A06B-6088-H215#H500 spindle amp.
  1. Replies: 5
    Last Post: 11-13-2017, 04:45 PM
  2. fanuc drillmate / robo drill alarm 1006 clamp
    By goodplastics in forum Fanuc
    Last Post: 07-30-2015, 12:19 PM
  3. fanuc o-t alarm 1006 tool position error
    By Korellibopper in forum Fanuc
    Last Post: 11-18-2011, 06:48 PM
  4. Fanuc OT alarms
    By cncmike92 in forum Daewoo/Doosan
    Last Post: 04-23-2007, 01:57 PM
  5. Fanuc O-m Alarm 1006
    By CNCEDMDUDE in forum Fanuc
    Last Post: 09-01-2006, 02:13 AM
