Originally Posted by
djcregan
Hi
Looking for some help with the above, I have been away and come back to a problem with the tool changing.
Its breaking tool holder forks as the alignment on the x axis is out by approx 2 - 3mm, everything suggests that the machine has hit something but will never know, I do know it broke an 8mm tool, so something quite hefty.
I have tried adjusting using parameter 881 which adjusts the negative retract on the z but it isn't quite enough. Alternatively there must be a parameter which adjusts the distance to the first tool folder from x =0 or something similar but I cant find it.
Any advice as always would be much appreciated.
Thanks in anticipation
