587,380 active members*
4,290 visitors online*
Results 1 to 11 of 11
    Sep 2017
    14
    CNC Router D-code
    Does anyone have one of these CNC Router 3040 4 axis Controllers (CNCest Brand) If so, Do you know how to program the D-code on the controller box pad. That is if it can be programmed. I just watched a video on YouTube about programming a different style of controller using their P-code. It got me thinking maybe my controller could be programmed also, it shows a D-code I believe. The instructions that came with the CNC Router is minimal at its best, with no information on, or if the controller could be programmed.
    Thank You
    Dan
    Apr 2004
    5747
    Re: CNC Router D-code
    I've never heard of D-code, or P-code, for that matter. That's not to say it might not exist, but if so, it's rare. Most the code that runs CNC machines is called "G-code". You can write it by hand for simple projects, but it's a lot easier to feed your models or drawings to a CAM program and let it do that. I don't think that control box has a keypad capable of writing code (of any type). The buttons on it will move the axes, or start and stop the spindle; that's about it. Your programs are written elsewhere, and loaded using the control software that came (or should have come) with the machine.
    Andrew Werby
    Website
    Sep 2017
    14
    I am not talking about the g-code used to run a job. Maybe D-code and P-code is a bad choice of words. In the video it was a different controller, so in the touch pad readout it showed a "P" with zeros after it. (P000) On my touch pad on the front of my controller it shows on the read out a "D" with zeros after it. (D000) That why I called it D and P code. In the video it showed that by changing the zero to numbers it change the controller functions from auto, manual and setup the spindle to communicate with the Mach 3 software so the software can control the spindle. As of now the only way I can control the speed of the spindle is the knob on the controller. If i switch to the computer mode, the spindle only goes full speed and no control. Being the controller in the video is different than mine, their information does not apply to my controller settings. I know you can change the values on the touch pad on my controller, but I don't know what it means, or how id effects the CNC spindle function. I though maybe someone had the same controller that understands what the value changes are and use them properly. I sort of figured, if the touch pad had not function, then they would not have put it on there, they would have just put a knob by it self.
    Sep 2017
    14
    After doing a little checking, I think what I am trying to say is I need to find out how to set the codes in the my VFD.
    Oct 2016
    Quote Originally Posted by Dreamaker View Post
    Search for the manufactures instruction manual online. Do not use someone else’s settings unless you know you have the same vfd. There are several out there and look very similar which makes this tough. There should have been a small book that came with you vfd that lists which each setting is for and a suggested default value for that setting. If your spindle is running properly without messing with these settings I would not suggest to change them unless you know what you are doing.
    Sep 2017
    14
    The booklet that came with the CNC Engraver/Router has nothing in it for setting the VFD. It would be nice to have the G-code control the spindle speed or adjust it in Mach 3. Also would like to see if the manufacture settings are correct and conform to Mach 3.
    35538
    You need to tell us what brand and model the VFD is, how it's wired to your breakout board, and the model of the breakout board. Pictures would help, if it's a no name chinese breakout board.
    Sep 2017
    14
    The name on the CNC is "CNCEST" Here is a pic for a start, I have to open the box to get the rest of them.
    Thank You
    Dan
    Nov 2018
    I don’t know if you made any progress but I found this information of the VFD settings
    https://www.cnczone.com/forums/attac...8&d=1542999945
    Sep 2017
    14
    Quote Originally Posted by bzytaz13 View Post
    Thank You!!!
    Dan
    Sep 2017
    14
    Thank You!!!!
    Dan
  1. Using g code on old router..WIll this code work?
    By graemeian in forum CNC Machining Centers
    Last Post: 04-19-2017, 11:34 PM
  2. Error code on SCM Router
    By TQ-CIWOOD in forum XYZ Gantry Routers
    Last Post: 01-27-2017, 03:37 PM
  3. G-code for router
    By LordyGordy in forum G-Code Programing
    Last Post: 01-14-2016, 11:59 PM
  4. About CNC Wood Router G Code
    By omnicnc in forum Omni CNC
    Last Post: 05-24-2012, 07:12 AM
  5. G-Code Router Plans ?
    By deleteallusers in forum DIY CNC Router Table Machines
    Last Post: 05-04-2007, 07:47 PM
