Originally Posted by
NIC 77
Is this a single phase spindle?
220V x 24A = 5280 Watts
3800 / 5280 = 72% efficient, so that actually makes sense. Also, higher quality spindles will usually be able to output more power than the rating for a short time, so perhaps its more efficient than that, and the max amp draw you're looking at includes the short term overload. I don't know if this is the case. Single phase is less efficient than three phase I believe.
Some of the cheaper spindles might list the electrical input power used as the spindle rating, so it's not the same thing because obviously the spindle is not 100% efficient.
If the spindle is 3 phase, then 220 x 24 x 1.73 = 9.1 kW which makes no sense at all. Not sure I've ever come across a high quality single phase ATC spindle?
You'd need a single phase output VFD to run it. Something doesn't sound right about this to me. Where exactly did it say 24 Amps?
