587,714 active members*
5,335 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach 770 - Minimum Starter Setup
Page 3 of 4 1234
Results 41 to 60 of 62
  1. #41
    Jul 2004
    1424
    Re: Tormach 770 - Minimum Starter Setup
    Quote Originally Posted by Viroos View Post
    Thanks, now I see.
    Another question: should I buy the dedicated 1280 x 1024 (4:3) monitor, or the Pathpilot will work on any other FullHD screen?
    I have mine on a cheap 22" 1920x1080 screen. Looks great.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  2. #42
    Jan 2012
    97
    I am running my 770 on an Asus 16:9 HD monitor. When PP starts, it reverts to a default 1024 x 768 resolution so circles become ellipses but otherwise it runs OK.
    RJ
  3. #43
    May 2016
    138
    I ran a 16:9 its fine. I did upgrade to the tough screen that I bought from monoprice (19" for $180 on sale) and its REALLY nice, I didnt think it would make life that much easier but it really does.
    The power drawbar is something I didnt get at first, $1200 is a good chunk of change, but it is an unbelievable time saver. I have some ops with 8+ tool changes! 2 min each , vs a few seconds each.. Its allowed me to get a lot more done in the limited free time I have
  4. #44
    Oct 2017
    51
    Just wanted to thank you all guys, today I ordered the machine, cannot wait to receive it and start making chips!
  5. #45
    Nov 2016
    151
    Congrats.
  6. #46
    Nov 2016
    151
    Quote Originally Posted by narrobb View Post
    My question is regarding PathPilot Controller; I initially thought while looking at Tormach online store that PP Controller is just the software which runs the G-code (something like MACH3) but now i learned from this thread that the PP Controller code also include a PC. So can I cancel that from the order and expect they should send the PP software on DVD? And does it include includes Linux? So if i get a new cheaper option All-in-one PC with built in TouchScreen (comes with Windows 10) then this DVD can replace Windows and install PP? So i just need PCI board right?
    I also like the idea of removing their stand and get a "Little Giant Table". Forgetting about the flood coolant and maybe go to the fog mister? Any input?
    With these savings, then power drawbar can be bought.
    Now about the 4" Axis, if the parts require milling from multiple sides, i assume this can be done manually but for those who have the 4th Axis, any input on the time vs money is highly appreciated (hobby and small quantity usage)
    Thanks guys.
    Ned
    The "Controller" is the PC and Path Pilot is the software. People have used a different PC, but you have to buy the controller card and your PC must have a slot to install it in. One of the advantages of Path Pilot is that it uses a dedicated controller card to communicate to with the mill, and it also uses Linux instead of Windows, which allows it to avoid pauses caused by Windows. I haven't looked on my CD (Path Pilot came installed), so I don't know it it includes Linux.
    You can certainly get by with the little giant table and fog buster. I wouldn't do it with flood.
    I like what this guy did with an 1100 ...
    https://www.youtube.com/watch?v=4YOtbSDSXNA
  7. #47
    Apr 2013
    1788
    The install DVD includes Linux. Just boot from the DVD and everything is installed onto a virgin machine. I have a Tormach controller that came with my original order and had Mach3 installed. However, I've been running my 770 on a junque HP mid-tower machine. Order the install kit -- 5i25 card plus DVD -- and save a few dollars.
  8. #48
    Nov 2017
    101
    Thanks guys. Glad i asked, so these all-in-one touchscreen PCs wont work as normally no space to add extra cards.
  9. #49
    Apr 2013
    1788
    A PCI-E slot is required.
  10. #50
    Sep 2009
    624
    Quote Originally Posted by syscore View Post
    There's a separate thread on 1100 fan and shroud; a kit was available from Nitewatchman.
  11. #51
    Oct 2017
    51
    Here we go
  12. #52
    May 2016
    138
    Nice!
  13. #53
    Apr 2013
    1788
    If the building with the red door is your workshop I hope that you are not as fat as I am!
  14. #54
    Oct 2017
    51
    Bwahaha!
    I wish I had more space
    Also hope the floor won't collapse, feels pretty flimsy...
  15. #55
    Mar 2016
    54
    Bwahaha!
    I got my 770 into a 49" width between 2 walls including custom enclosure. The X travel on the left needs a 'hinged letterbox' allowing it to go into the wall thickness (but no more). Most of the good ideas for the enclosure came from Cliff Hall - 'Threadexpress' on YouTube, 'Keen' on here, all of which were gratefully received and copied! I've been using it for over a year now, with no complaints about lack of space or accessability, but all my work is small enough to fit within the mill's envelope.
    Cheers, Andy
  16. #56
    Oct 2017
    51
    Wow, that's really tight!
    Another question, just don't want to open another thread: the floor in the shed is pretty flimsy and the whole machine is shaking when the table is moving. Is it a problem, or the frame of the machine is rigid enough to keep the precision?
    Not really excited about removing the floor and pouring concrete instead...
  17. #57
    Nov 2016
    151
    Yeah, that will be a problem. It doesn't take much lean to affect the cut by a few thou. At least on the 1100 that is how it is. It isn't the rigidity that is the issue as much as it is the weight. The slightest lean will cause a twist. I guess it depends on how much it shakes.
  18. #58
    Mar 2016
    54
    I'd get a couple of lengths of box-section steel tube, say 50x50x5 thick and use them as bearers under the machine's feet. Make the length(s) around 2x (min) the width of the base and sit the machine in the middle. This will spread the load better on the wooden floor. Aim to have the bearers both level so as to not induce twist in the base of the machine. If the floor is boarded, try to orient the machine so the bearers are 90 degrees to the direction of the boards.
    Cheers, Andy
  19. #59
    Oct 2017
    51
    The whole floor is shaking, I feel like this summer I gonna swallow a lot of concrete dust...
    Is it OK to attach the fog buster container to the base under the chip tray, or it's too low?
  20. #60
    Oct 2017
    51
    Fresh thoughts following the assembly of the machine. I really regret for not adding the arm to my shopping list. I would say it should be a part of a minimum setup, otherwise good luck finding a good place to the monitor and the rest of input devices. Buying it now isn't an option - the shipping costs more than the arm itself, so I'm definitely going to add it to my next big shopping with Tormach.
Page 3 of 4 1234
  1. TORMACH 15L SLANT-PRO CNC Lathe: Unbox and Setup Log Video
    By s2jesse in forum Tormach Slant Lathe
    Last Post: 02-15-2016, 06:33 AM
  2. Tormach, Rhino and Sprutcam setup insight
    By CadRhino in forum Tormach Personal CNC Mill
    Last Post: 10-12-2014, 02:49 PM
  3. New Tormach setup w/ Smoothstepper
    By jberend in forum SmoothStepper Motion Control
    Last Post: 03-09-2014, 09:55 PM
  4. Initial setup of used tormach?
    By widget_maker in forum Tormach Personal CNC Mill
    Last Post: 03-08-2014, 12:36 AM
  5. Tormach passive probe setup.
    By mrquacker in forum Tormach Personal CNC Mill
    Last Post: 05-30-2013, 03:41 AM
