587,833 active members*
3,541 visitors online*
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    May 2015
    60
    Re: Is Solid Works worth learning?
    If I have to cut an aluminum bracket,,,because the finishers damaged one,,,best believe I will NOT be making a 3d model,,,
    dxf file
    imprt to hurac turn cam
    select tool
    select depth
    feeds and speeds are set from the tool manager —-machine
    check guards/safety mats/fence
    reset ,,clear ,,,run,,,(green/white button)
  2. #42
    Feb 2006
    7063
    Why would you even bother to do a drawing to cut a rectangle? I could do that entirely with my pendant, or a few lines of hand-entered g-code, and be done before you even finished your drawing. I thought we were having a serious conversation about making real parts, not just trying to win an argument....
    Regards,
    Ray L.
  3. #43
    May 2015
    60
    Yes yes,,,the handheld would probably be the best bet,,,,where is your shop out of
  4. #44
    May 2006
    804
    Ponder this regarding any software dilemma, just from this last few posts
    All cad systems generate geometry.
    All cam systems generate Gcode
    One should be able to make things on any system you or the boss owns,
    They all do the same in the end.
    What do you want to do with these CAD/CAM tools?
    ya can't program a 7axis robot with autocad r10.
    (that was done with Fortran before acad 01)
    Learn the process and principals and application of CAD and CAM
    It takes years then you can do anything..
  5. #45
    May 2015
    60
    Direct programming is stilling challenging for me(robot arm) the code is c++,,,,roboguide has templates and actually you can do a lot of work directly through the plc with rslogix,,,
    keysoftwareservice.com. If I can help
  6. #46
    May 2015
    60
    As per the last few post,,,I was just bored picking fuss with a more experienced operator ; )
  7. #47
    Mar 2015
    178
    The question was is SW worth learning. I say yes. Its worth learning. $90 even for 1 year license is a bargain. Although so is 360 or any other decent CAD software at that price. I think maybe the real question is is the time investment to learn worth it.
Page 3 of 3 123
  1. negative of a solid in solid works
    By ringanator in forum Solidworks
    Last Post: 02-09-2015, 03:58 PM
  2. Replies: 6
    Last Post: 01-13-2014, 06:29 AM
  3. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  4. Solid works!
    By LT1TRUCK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2008, 03:22 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
