Originally Posted by
Rexford
Alan,I have a Prolight 1000 and am running it with the original black control box and using Mach3. I do not have the pro light control card. I am using a $15.00 break out board from Ebay in its place. I use a little OpAmp circuit to change the break out board PWM 0 - 5 V to 0 - 10 V for the spindle speed. Connections: The Computer to breakout board via parallel cable. From breakout board to Black control box via a parallel cable that has had one end cut off and wired to the breakout board with the connections found else where in this thread. Then that parallel cable is plugged into the Black box. This works only on 32 bit computers. I have just last week updated to a 64 bit computer by placing a Smooth Stepper in be tween the computer and break out board. The Smooth Stepper operates with a USB cable to the computer. If you choose this route I would recommend getting the mill running with a 32 bit and break out board first then Change to the 64 bit with the Smooth Stepper.If there is interest in what I did I may try to put some drawings , pictures and detail on a web sight some where.While I am here I have a Prolight 2000 which has servo motors I would like to switch to mach3 if anyone knows how to do that. It run now on the old DOS system. Rexford
