Forhire, your newest post is not working for me at all. I have attached the model of the part I have been working with. For example with the twist drill (T20) in the "Front" setup the height From the top point to the bottom in fusion is about 2.875" but your gcode exports a cycle with a depth of 3.9652". Your previous post before I mentioned the "getCommonCycle(x, y, (cycle.bottom*-1+cycle.clearance))"worked well enough for us. We desperately need to be able to use drill ops right now.
*no attatchment because apparently the file format is not supported.
