588,009 active members*
3,254 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Upgrade of Huanyang vfd
Page 11 of 19 910111213
Results 201 to 220 of 378
  1. #201
    Jun 2017
    238
    Re: Upgrade of Huanyang vfd
    Quote Originally Posted by ericks View Post
    does it go up from 0 - 400??
    Yeah on the main screen not a parameter setting
    Sent from my SM-G935F using Tapatalk
  2. #202
    ericks Guest
    Thats the one i want....main screen....i need to know if you are able to increase the value on the screen by using this external pot you connected up
  3. #203
    ericks Guest
    That hz value must go up and down when you turn the external pot that you connected....does it?
  4. #204
    Jun 2017
    238
    No 0-400hz pot doesn't do anything
  5. #205
    ericks Guest
    Quote Originally Posted by potts43 View Post
    understood....okay while it is in this state go to 16-02 and read the value there for me
  6. #206
    Jun 2017
    238
    100%
  7. #207
    ericks Guest
    turn the external pot and see if this value changes please
  8. #208
    Jun 2017
    238
    No stays at 100%
  9. #209
    ericks Guest
    okay we getting somewhere now....you sure you connected the pot correctly?
  10. #210
    ericks Guest
    Those four dip switches on the drive....fourth one must be down/off
  11. #211
    Jun 2017
    238
    It's how I was told
  12. #212
    Jun 2017
    238
    All down
  13. #213
    Jun 2017
    238
    Wires ok?
  14. #214
    ericks Guest
    Please make sure these are set
    3-00[0]
    3-10[0.00]
    3-12[0]
    3-14[0]
    3-15[1]
    3-16[1]
    3-17[1]
    3-18[0]
  15. #215
    ericks Guest
    okay your pot is connected properly...just checking
    stop the drive.....set the parameter values i gave you....then turn the power off to the drive till its fully shut down. power up again then make sure you in auto then try and change the Hz value in main screen again with the ext pot...thanks
  16. #216
    ericks Guest
    another parameter 6-01[0]
  17. #217
    ericks Guest
    I have to go through and check if some parameters were changed...
    6-10[0.07V]
    6-11[10V]
    6-14[0]
    6-15[50]
    6-19[0]
    6-80[0] we will disable the onboard pot for now
  18. #218
    ericks Guest
    This has to work....if it doesn't then i have one more option
  19. #219
    Jun 2017
    238
    Hit it with a hammer?
  20. #220
    ericks Guest
    Have you done all those parameters?
  1. Huanyang VFD
    By lt00273 in forum Chinese Machines
    Last Post: 09-13-2017, 04:55 AM
  2. Huanyang VFD
    By lt00273 in forum Spindles / VFD
    Last Post: 09-07-2017, 06:10 PM
  3. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  4. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  5. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
