587,579 active members*
3,590 visitors online*
Results 1 to 10 of 10
    Nov 2005
    111
    LinuxCNC and Laptop
    Hello,
    does someone knows a way to control a cnc-machine with a laptop using usb or network? In the Github i found a project RT-8p8c. Does someone knows this project or works with it? The last change in the Git is four years old.
    I have a very small pcb milling machine and when i use a PC, the PC with Display, Keybord and Mouse is greater the the milling machine. Maybe its possible to control a cnc with a raspberry pi and make the communication to the raspberry pi with a laptop?
    Hans
    Jun 2009
    251
    Quote Originally Posted by Holzwurm56 View Post
    Hello,
    Hans
    Try machinekit, that might be what you are looking for.
    Nov 2005
    111
    Re: LinuxCNC and Laptop
    Hello Tommylight,
    can you tell me what is machinekit?
    Hans
    Jul 2014
    51
    Have you tried Googling Machinekit, I don't think so.
    If you do you will find a lot of information on the subject.
    Nov 2005
    111
    Hi hoecken,
    i see machinekit, maybe i am to silly but i do not understand what machinekit is. For me its nearly the same as linuxcnc.
    Hans
    1943
    Hi hoecken,
    Hans
    Machinekit is basically LinuxCNC on a BeagleBone black mini computer
    Your only option for using laptop is via ethernet. Mesa makes ethernet FPGA cards that could possibly work.
    Nov 2011
    137
    I use a dell D610 laptop with my cnc, It has a parallel port,Im using the c1g breakout board with usb hooked up to it for 5volts.Ran that 5 volts to each gecko 202s 3-axis with stepper motors connected to them have no. 2,4,6,pins for steps and 3,5,7 for direction. been going that way for a number of years with our any problems, did have the geckos amps set at 4 amps with 65 volts on nema 23s ,but now running nema 17 with current and voltage cut back some
    Apr 2013
    1899
    ...have you considered other alternatives to LinuxCNC? UCCNC + UC100 (USB) or UC400ETH (Ethernet) together with a tablet would work just fine. You can even use WIFI, if you connect the UC400ETH to a switch and a wireless LAN.
    May 2015
    686
    The Mesa ethernet cards work very well and you don't need much of a PC to run it. Here's mine which I've just finished mounting to the touchscreen monitor I use.
    I just used the last of the 32 inputs on my Mesa 7i76e today.
    The problem with laptops is that LinuxCNC requires a low latency PC and with all of the power saving features of a laptop, they are very rarely suitable for LinuxCNC. The Gigabyte Brix shown has a Celeron J1900 processor and only cost me about $100.
    Machinekit is a fork of LinuxCNC. Other than that I know nothing about it.
    I don't know why on earth you would consider purchasing a commercial Windows based CNC system like UCCNC or a USB/Ethernet motion board when for a few $ more you can have a free open source system and a Mesa ethernet card with 5 stepgens, 32 inputs, 16 outputs, spindle control, encoder interface, 2 MPG inputs, 3-4 Analog inputs, and basically infinite expansion. For example, I could add 2 more daughter cards to treble the inputs for 15 stepgens etc and more cards via and amazing support from the vendor on the Linuxcnc forum. There is a reason why a number of commercial vendors who have adopted LinuxCNC.
    Rod Webster
    www.vehiclemods.net.au
    Jul 2003
    1759
    I agree with rod...
    $199 gets you everything rob explained + almost unlimited expandability..
    The uccnc + UC100 is $165 and you still need some sort of breakout board. (and a windows licence?)
    The uccnc + UC400ETH is $208 and again you still need a breakout board(s). (and a windows license?)
    There are laptops that play well with linuxcnc and rt_preempt.. I use mine for testing and it works great. Robs solution is cool too - there is a lot of options out there now.
    sam
  1. Buy laptop
    By pujasingh11 in forum Want To Buy...Need help!
    Last Post: 02-10-2012, 08:06 AM
  2. Laptop for CAD/CAM
    By junglist in forum BobCad-Cam
    Last Post: 02-17-2011, 03:50 AM
  3. DNC with a laptop and a VMC 40.
    By neilthib in forum Fadal
    Last Post: 11-01-2010, 02:41 AM
